Vista Tutorial - USB-Massstorage Driver Problems
Old 08-05-2007   #1 (permalink)
Tattva
Guest
Hi there
my problem is that Windows Vista (Ultimate, 64Bit) can't find the standard
USB-Massstorage driver ... When I connect a USB Stick or MP3 Player or my
mobile phone to the USB port (any USB port) it says it needs a driver and
when I say go and get it ... look for it ... it can't find any ... please
help me!
NO USB Storage device is working and I don't know what to do. This is so
rediculous ... I bought Windows and can't get USB to work ...
Old 08-05-2007   #2 (permalink)
PvdG42
Guest
Re: USB-Massstorage Driver Problems
"Tattva" <Tattva@discussions.microsoft.com> wrote in message
news:17266396-3EA4-4CA9-9FFA-AFD48F5C5619@microsoft.com...
> Hi there
> help me!
Problems with USB memory sticks are not uncommon in Vista and there is a fix
that appears to work for many (it worked for me).
Locate the file INFCACHE.1 on the PC. You'll find it in <OS
drive>\Windows\inf
Give yourself full control of INFCACHE.1 by right-clicking on it, then
Properties->Security->Edit to add your users group with full control.
Delete INFCACHE.1
Reboot your machine, then try the USB memory stick. Hopefully, Vista will
now find and install the needed driver.
Old 08-06-2007   #3 (permalink)
Uwe Sieber
Guest
Tattva wrote:
> Hi there
> help me!
Vista seems to tend to loose the files USBSTOR.INF and USBSTOR.PNF from
C:\Windows\INF. Probably there are more files missing then but the
USBSTOR files are most frequently used ones.
There are copies of the files in
C:\Windows\System32\DriverStore\FileRepository - just copy them to
C:\Windows\INF.
Uwe
Problems with CD driver Vista hardware & devices
DVD/CD Driver problems Drivers
External Hard Drive (USB MassStorage Device missing?) Vista hardware & devices
DVD driver problems Vista General
Driver problems Vista installation & setup
