| | Problem adding second DVD drive in Vista Hi all- I am running a Vista 64-bit machine that is set up as follows: 2x Seagate 250GB hard drives connected via SATA and running in IDE mode (non RAID) NEC DVD-RW connected via IDE Everything was working fine, and I purchased a second DVD-RW (Samsung) to add to my system. I daisy-chained it to the same IDE cable as the first DVD drive. But after booting, I could not access the new drive. The nearest support articles I found first instructed me to clear the upper range of some filter in the registry, which didn't quite sound right since I was adding a drive after I had everythihg working in Vista. Deeper checking led me to believe that I need to adjust the jumper settings on the drives, which were both set to master. I changed them both to CSEL. Now Vista reports that I have 3 DVD drives. Trying to understand what the jumpers should be is getting me nowhere since all the documentation I have found refers to having a DVD daisy-chained off the hard disk ATA cable and nothing about my configuration with hard disks on SATA and only two DVD daisy-chained on IDE. Here are my questions: 1) What should my DVD jumpers be set at? master/slave or csel/csel or master/csel? 2) Is there a performance concern between different jumper settings (as I saw discussed for master/slave harddisk/dvd)? 3) How do I get Vista to reflect only 2 DVD drives, as that is what is on the machine (I suspect question 1 solves this)? Thanks very much for your assistance, Mason |
| | RE: Problem adding second DVD drive in Vista When you Daisy Chain with IDE one needs to be set to master and the other to slave. Usualy there's only 2 hookups on an IDE Cable, but if you have more then you need to set a 3rd to CSEL. I think that's the common Jumper setting when using a Third Drive. I know using a Third Drive can cause conflicts, even with Jumpers set right. With all the jumpers set to the same, it's blowing your BIOS's Mind, that's why it now thinks you have 3 Drives. It's trying to figure out why there's 2 set up as slave 3rd Drive and is assumong you have the first (Maser) Hooked up somewhere else. Does any of your DVD, CD drives have a SATA connector? If your M-Board has enough SATA Plugs this would be the best way to go. Not to mention you get much better transfer rates with SATA and allot less Headaches. "Mason" wrote: > Hi all- > > I am running a Vista 64-bit machine that is set up as follows: > > 2x Seagate 250GB hard drives connected via SATA and running in IDE mode (non > RAID) > NEC DVD-RW connected via IDE > > Everything was working fine, and I purchased a second DVD-RW (Samsung) to > add to my system. I daisy-chained it to the same IDE cable as the first DVD > drive. But after booting, I could not access the new drive. The nearest > support articles I found first instructed me to clear the upper range of > some filter in the registry, which didn't quite sound right since I was > adding a drive after I had everythihg working in Vista. > > Deeper checking led me to believe that I need to adjust the jumper settings > on the drives, which were both set to master. I changed them both to CSEL. > Now Vista reports that I have 3 DVD drives. Trying to understand what the > jumpers should be is getting me nowhere since all the documentation I have > found refers to having a DVD daisy-chained off the hard disk ATA cable and > nothing about my configuration with hard disks on SATA and only two DVD > daisy-chained on IDE. Here are my questions: > > 1) What should my DVD jumpers be set at? master/slave or csel/csel or > master/csel? > > 2) Is there a performance concern between different jumper settings (as I > saw discussed for master/slave harddisk/dvd)? > > 3) How do I get Vista to reflect only 2 DVD drives, as that is what is on > the machine (I suspect question 1 solves this)? > > Thanks very much for your assistance, > Mason > > |
| | Re: Problem adding second DVD drive in Vista The original NEC DVD-Rw should be set as master. Your new one should be set as slave. I just installed a additional player and this setup worked fine. Go Luck. -- "KentuckyRanger" <KentuckyRanger@discussions.microsoft.com> wrote in message news:FEF437AD-06BD-4709-B5EA-5B37F62B129D@microsoft.com... > When you Daisy Chain with IDE one needs to be set to master and the other > to > slave. Usualy there's only 2 hookups on an IDE Cable, but if you have more > then you need to set a 3rd to CSEL. I think that's the common Jumper > setting > when using a Third Drive. I know using a Third Drive can cause conflicts, > even with Jumpers set right. With all the jumpers set to the same, it's > blowing your BIOS's Mind, that's why it now thinks you have 3 Drives. It's > trying to figure out why there's 2 set up as slave 3rd Drive and is > assumong > you have the first (Maser) Hooked up somewhere else. > Does any of your DVD, CD drives have a SATA connector? If your M-Board has > enough SATA Plugs this would be the best way to go. Not to mention you get > much better transfer rates with SATA and allot less Headaches. > > "Mason" wrote: > >> Hi all- >> >> I am running a Vista 64-bit machine that is set up as follows: >> >> 2x Seagate 250GB hard drives connected via SATA and running in IDE mode >> (non >> RAID) >> NEC DVD-RW connected via IDE >> >> Everything was working fine, and I purchased a second DVD-RW (Samsung) to >> add to my system. I daisy-chained it to the same IDE cable as the first >> DVD >> drive. But after booting, I could not access the new drive. The nearest >> support articles I found first instructed me to clear the upper range of >> some filter in the registry, which didn't quite sound right since I was >> adding a drive after I had everythihg working in Vista. >> >> Deeper checking led me to believe that I need to adjust the jumper >> settings >> on the drives, which were both set to master. I changed them both to >> CSEL. >> Now Vista reports that I have 3 DVD drives. Trying to understand what >> the >> jumpers should be is getting me nowhere since all the documentation I >> have >> found refers to having a DVD daisy-chained off the hard disk ATA cable >> and >> nothing about my configuration with hard disks on SATA and only two DVD >> daisy-chained on IDE. Here are my questions: >> >> 1) What should my DVD jumpers be set at? master/slave or csel/csel or >> master/csel? >> >> 2) Is there a performance concern between different jumper settings (as >> I >> saw discussed for master/slave harddisk/dvd)? >> >> 3) How do I get Vista to reflect only 2 DVD drives, as that is what is >> on >> the machine (I suspect question 1 solves this)? >> >> Thanks very much for your assistance, >> Mason >> >> |
| Adding a new PageFile on another drive than the system drive | PowerShell | |||
| Vista Ultimate-adding hard drive | Vista installation & setup | |||
| Adding e-SATA Drive Changes Physical Disk 0 in Logical Disk Manager - Any Problem? | Vista General | |||
| Adding e-SATA Drive Changes Physical Disk 0 in Logical Disk Manager - Any Problem? | Vista hardware & devices | |||
| Problem Adding New Drive After Installation | Vista installation & setup | |||
