Vista - Very strange sound prob
Old 08-14-2007   #11 (permalink)
rbwillm
Re: Very strange sound prob
Realtek ac97 audio
Rob
"Cal Bear '66" wrote:
> Go to Control Panel > Device Manager > expand Sound, video and game controllers.
> The audio adapter will be listed there (Realtek, Sigma Tel, etc.)
> I Bleed Blue and Gold
> GO BEARS!
> "rbwillm" <rbwillm@discussions.microsoft.com> wrote in message
> news:AC4519F8-1929-4C38-9728-B09F9A9AEA79@microsoft.com...
> > I'm just using the motherboard audio & vista installed the drivers for that.
> > Rob
> >> What is your audio adapter?
> >> I would recommend a complete removal of your current audio drivers and any
> >> utilities and a reinstall of the latest Vista drivers.
> >> GO BEARS!
> >> news:A495368E-BB5A-4E7D-AA71-1A72AA3A2D9D@microsoft.com...
> >> > Hi Cal Bear, I have looked at what you suggested & all volumes are turned
> >> > on,
> >> > when I go to control panel, click on configure & run the test I can hear
> >> > the
> >> > sound. Still no sound from general windows sound though. Thanks for your
> >> > suggestions.
> >> > Rob
> >> >> The Mute button at the bottom of the Windows Sounds slider does not a a
> >> >> very
> >> >> tiny red crossed circle does it?
> >> >> When you right click on the Speaker icon in the Notification Area of the
> >> >> Taskbar
> >> >> and select Sounds have you checked that the sound notifications you want
> >> >> are
> >> >> enabled, and have you tested them from there?
> >> >> GO BEARS!
> >> >> news:3B1A135B-98C0-4F6D-9558-C6BC5F39DF65@microsoft.com...
> >> >> > Thanks for the response Doug, I checked the System volume & it's at the
> >> >> > same
> >> >> > level as all the other volume indicators, level 38.
> >> >> > Rob
> >> >> > "Douglas O'Neill" wrote:
> >> >> >> Apologies if you have tried this already... click once on the volume
> >> >> >> control
> >> >> >> icon on the taskbar, then click on mixer. Is the Windows Sounds
> >> >> >> setting
> >> >> >> turned all the way down?
> >> >> >> Doug
> >> >> >> news:4E804CFD-B780-444F-B2BA-055F646B787C@microsoft.com...
> >> >> >> > Howdy all, I have a real weird one, i'm running home premium & can't
> >> >> >> > get
> >> >> >> > any
> >> >> >> > sound from the general windows sounds (minimise, recycle) but can get
> >> >> >> > sound
> >> >> >> > from windows media player & itunes, my drivers are up to date & i
> >> >> >> > have
> >> >> >> > checked all the settings & properties.
> >> >> >> > Rob
Old 08-14-2007   #12 (permalink)
Cal Bear '66
For ac97 Vista drivers go here:
http://www.realtek.com.tw/downloads/...&GetDown=false
Note: I am not familiar with the ac97 drivers (only Realtek HD Audio here), but
you may have to run the install twice--once to remove the old drivers and once
to then install the newer drivers.
GO BEARS!
news:C16945A9-7E30-4064-A581-932D3482E83B@microsoft.com...
> Realtek ac97 audio
> Rob
>> controllers.
>> GO BEARS!
>> > that.
>> > Rob
>> >> GO BEARS!
>> >> > turned
>> >> > on,
>> >> > the
>> >> > suggestions.
>> >> > Rob
>> >> >> very
>> >> >> the
>> >> >> Taskbar
>> >> >> want
>> >> >> are
>> >> >> GO BEARS!
>> >> >> > the
>> >> >> > same
>> >> >> > Rob
>> >> >> >> control
>> >> >> >> setting
>> >> >> >> Doug
>> >> >> >> > can't
>> >> >> >> > get
>> >> >> >> > any
>> >> >> >> > get
>> >> >> >> > sound
>> >> >> >> > have
>> >> >> >> > Rob
Old 08-15-2007   #13 (permalink)
rbwillm
Thanks for that Cal Bear 66, will give it a try.
Rob
> GO BEARS!
> > Realtek ac97 audio
> > Rob
> >> controllers.
> >> GO BEARS!
> >> > that.
> >> > Rob
> >> >> GO BEARS!
> >> >> > turned
> >> >> > on,
> >> >> > the
> >> >> > suggestions.
> >> >> > Rob
> >> >> >> very
> >> >> >> the
> >> >> >> Taskbar
> >> >> >> want
> >> >> >> are
> >> >> >> GO BEARS!
> >> >> >> > the
> >> >> >> > same
> >> >> >> > Rob
> >> >> >> >> control
> >> >> >> >> setting
> >> >> >> >> Doug
> >> >> >> >> > can't
> >> >> >> >> > get
> >> >> >> >> > any
> >> >> >> >> > get
> >> >> >> >> > sound
> >> >> >> >> > have
> >> >> >> >> > Rob
Old 08-17-2007   #14 (permalink)
rbwillm
I downloaded & installed the vista file at the site you said Cal Bear 66 but
still no good, sounds still come from Media player, MSN & Itunes though.
Rob
> Rob
> > GO BEARS!
> > > Realtek ac97 audio
> > > Rob
> > >> controllers.
> > >> GO BEARS!
> > >> > that.
> > >> > Rob
> > >> >> GO BEARS!
> > >> >> > turned
> > >> >> > on,
> > >> >> > the
> > >> >> > suggestions.
> > >> >> > Rob
> > >> >> >> very
> > >> >> >> the
> > >> >> >> Taskbar
> > >> >> >> want
> > >> >> >> are
> > >> >> >> GO BEARS!
> > >> >> >> > the
> > >> >> >> > same
> > >> >> >> > Rob
> > >> >> >> >> control
> > >> >> >> >> setting
> > >> >> >> >> Doug
> > >> >> >> >> > can't
> > >> >> >> >> > get
> > >> >> >> >> > any
> > >> >> >> >> > get
> > >> >> >> >> > sound
> > >> >> >> >> > have
> > >> >> >> >> > Rob
Old 08-22-2007   #15 (permalink)
Michael D
Did you always have this problem or did it just start recently, I ask
because I installed a windows update from Realtek and lost audio just
yesterday so I went into device manager and rolled back to the previous
driver and now all is good. I think the problem is that I have SoundMAX
onboard but windows updated with RealTek drivers and if you have windows
automatically update this may have happened to you.
news:EC441A07-0EF2-41AD-9FA9-D1AB21679F18@microsoft.com...
>but
> Rob
>> Rob
>> > here), but
>> > and once
>> > GO BEARS!
>> > > Realtek ac97 audio
>> > > Rob
>> > >> controllers.
>> > >> GO BEARS!
>> > >> > for
>> > >> > that.
>> > >> > Rob
>> > >> >> drivers and any
>> > >> >> GO BEARS!
>> > >> >> > are
>> > >> >> > turned
>> > >> >> > on,
>> > >> >> > can hear
>> > >> >> > the
>> > >> >> > for your
>> > >> >> > suggestions.
>> > >> >> > Rob
>> > >> >> >> does not a a
>> > >> >> >> very
>> > >> >> >> Area of
>> > >> >> >> the
>> > >> >> >> Taskbar
>> > >> >> >> notifications you
>> > >> >> >> want
>> > >> >> >> are
>> > >> >> >> GO BEARS!
>> > >> >> >> > it's at
>> > >> >> >> > the
>> > >> >> >> > same
>> > >> >> >> > Rob
>> > >> >> >> >> the volume
>> > >> >> >> >> control
>> > >> >> >> >> Sounds
>> > >> >> >> >> setting
>> > >> >> >> >> Doug
>> > >> >> >> >> message
>> > >> >> >> >> > premium &
>> > >> >> >> >> > can't
>> > >> >> >> >> > get
>> > >> >> >> >> > any
>> > >> >> >> >> > but can
>> > >> >> >> >> > get
>> > >> >> >> >> > sound
>> > >> >> >> >> > date & i
>> > >> >> >> >> > have
>> > >> >> >> >> > Rob
Old 08-23-2007   #16 (permalink)
rbwillm
hey Michael D, I did have sound originally, couldn't tell you when I lost it
though, just realised that it wasn't working one day. Will try rolling back
the driver but the only thing is I downloaded a large driver file from
realtek, will see what happens. Thanks for the info.
Rob
> >but
> > Rob
> >> Rob
> >> > here), but
> >> > and once
> >> > GO BEARS!
> >> > > Realtek ac97 audio
> >> > > Rob
> >> > >> controllers.
> >> > >> GO BEARS!
> >> > >> > for
> >> > >> > that.
> >> > >> > Rob
> >> > >> >> drivers and any
> >> > >> >> GO BEARS!
> >> > >> >> > are
> >> > >> >> > turned
> >> > >> >> > on,
> >> > >> >> > can hear
> >> > >> >> > the
> >> > >> >> > for your
> >> > >> >> > suggestions.
> >> > >> >> > Rob
> >> > >> >> >> does not a a
> >> > >> >> >> very
> >> > >> >> >> Area of
> >> > >> >> >> the
> >> > >> >> >> Taskbar
> >> > >> >> >> notifications you
> >> > >> >> >> want
> >> > >> >> >> are
> >> > >> >> >> GO BEARS!
> >> > >> >> >> > it's at
> >> > >> >> >> > the
> >> > >> >> >> > same
> >> > >> >> >> > Rob
> >> > >> >> >> >> the volume
> >> > >> >> >> >> control
> >> > >> >> >> >> Sounds
> >> > >> >> >> >> setting
> >> > >> >> >> >> Doug
> >> > >> >> >> >> message
> >> > >> >> >> >> > premium &
> >> > >> >> >> >> > can't
> >> > >> >> >> >> > get
> >> > >> >> >> >> > any
> >> > >> >> >> >> > but can
> >> > >> >> >> >> > get
> >> > >> >> >> >> > sound
> >> > >> >> >> >> > date & i
> >> > >> >> >> >> > have
> >> > >> >> >> >> > Rob
Old 08-23-2007   #17 (permalink)
vid
> >but
> > Rob
> >> Rob
> >> > here), but
> >> > and once
> >> > GO BEARS!
> >> > > Realtek ac97 audio
> >> > > Rob
> >> > >> controllers.
> >> > >> GO BEARS!
> >> > >> > for
> >> > >> > that.
> >> > >> > Rob
> >> > >> >> drivers and any
> >> > >> >> GO BEARS!
> >> > >> >> > are
> >> > >> >> > turned
> >> > >> >> > on,
> >> > >> >> > can hear
> >> > >> >> > the
> >> > >> >> > for your
> >> > >> >> > suggestions.
> >> > >> >> > Rob
> >> > >> >> >> does not a a
> >> > >> >> >> very
> >> > >> >> >> Area of
> >> > >> >> >> the
> >> > >> >> >> Taskbar
> >> > >> >> >> notifications you
> >> > >> >> >> want
> >> > >> >> >> are
> >> > >> >> >> GO BEARS!
> >> > >> >> >> > it's at
> >> > >> >> >> > the
> >> > >> >> >> > same
> >> > >> >> >> > Rob
> >> > >> >> >> >> the volume
> >> > >> >> >> >> control
> >> > >> >> >> >> Sounds
> >> > >> >> >> >> setting
> >> > >> >> >> >> Doug
> >> > >> >> >> >> message
> >> > >> >> >> >> > premium &
> >> > >> >> >> >> > can't
> >> > >> >> >> >> > get
> >> > >> >> >> >> > any
> >> > >> >> >> >> > but can
> >> > >> >> >> >> > get
> >> > >> >> >> >> > sound
> >> > >> >> >> >> > date & i
> >> > >> >> >> >> > have
> >> > >> >> >> >> > Rob
I to have the same problem. Have vista home premium edition 32 bit. Realtek
HD Audio. Everything is listed as in working order the volume has been turned
up full blast yet there is no sound in Media Center, Player or even Windows
Sounds. Speakers are plugged in correctly and everything tested and
presumably in working order. Anyone else have a suggestion ? Thanks
Old 08-23-2007   #18 (permalink)
Cal Bear '66
There is no red X on the Speaker icon in the Notification Area of the Taskbar?
In Control Panel (Classic view) > Device Manager > (expand Sound, video and game
controllers), there are no red circles or yellow exclamation points?
GO BEARS!
Old 08-24-2007   #19 (permalink)
rbwillm
All speaker options show that everything is turned on & working, also there
are no red circles or yellow exclamation points in sound, video & game
controllers. Even though I get no sound from any windows based sounds, when I
play the test that is in speaker setup it plays no probs at all.
Rob
> GO BEARS!
Strange sound problem! Vista General
Strange sound problem Vista General
Strange sound bites Vista General
Strange sound driver problem Vista hardware & devices
strange happenings with Sound Vista hardware & devices
