Vista Forums Home Join Vista Forums Donate Windows 7 Forum Vista Tutorials Tags
Welcome to Windows Vista Forums. Our forum is dedicated to helping you find solutions with any problems, errors or issues you are experiencing with Windows Vista. The Vista forum also covers news and updates and has an extensive Vista tutorial section that covers a wide range of tips and tricks.
Very strange sound prob
LinkBack Thread Tools Display Modes
Old 08-06-2007   #1 (permalink)
rbwillm
Guest
Howdy all, I have a real weird one, i'm running home premium & can't get any
sound from the general windows sounds (minimise, recycle) but can get sound
from windows media player & itunes, my drivers are up to date & i have
checked all the settings & properties.
Rob
Old 08-07-2007   #2 (permalink)
Douglas O'Neill
Guest
Re: Very strange sound prob
Apologies if you have tried this already... click once on the volume control
icon on the taskbar, then click on mixer. Is the Windows Sounds setting
turned all the way down?
Doug
"rbwillm" <rbwillm@discussions.microsoft.com> wrote in message
news:4E804CFD-B780-444F-B2BA-055F646B787C@microsoft.com...
> any
> sound
> Rob
Old 08-08-2007   #3 (permalink)
rbwillm
Guest
Thanks for the response Doug, I checked the System volume & it's at the same
level as all the other volume indicators, level 38.
Rob
> Doug
> > any
> > sound
> > Rob
Old 08-08-2007   #4 (permalink)
Cal Bear '66
Guest
The Mute button at the bottom of the Windows Sounds slider does not a a very
tiny red crossed circle does it?
When you right click on the Speaker icon in the Notification Area of the Taskbar
and select Sounds have you checked that the sound notifications you want are
enabled, and have you tested them from there?
I Bleed Blue and Gold
GO BEARS!
news:3B1A135B-98C0-4F6D-9558-C6BC5F39DF65@microsoft.com...
> Rob
>> Doug
>> > any
>> > sound
>> > Rob
Old 08-09-2007   #5 (permalink)
rbwillm
Guest
Hi Cal Bear, I have looked at what you suggested & all volumes are turned on,
when I go to control panel, click on configure & run the test I can hear the
sound. Still no sound from general windows sound though. Thanks for your
suggestions.
Rob
> GO BEARS!
> > Rob
> >> Doug
> >> > any
> >> > sound
> >> > Rob
Old 08-09-2007   #6 (permalink)
Cal Bear '66
Guest
What is your audio adapter?
I would recommend a complete removal of your current audio drivers and any
utilities and a reinstall of the latest Vista drivers.
GO BEARS!
news:A495368E-BB5A-4E7D-AA71-1A72AA3A2D9D@microsoft.com...
> suggestions.
> Rob
>> Taskbar
>> GO BEARS!
>> > same
>> > Rob
>> >> control
>> >> Doug
>> >> > any
>> >> > sound
>> >> > Rob
Old 08-11-2007   #7 (permalink)
Lisbeth Dahle
Guest
Have you perhaps disabled the window-sounds?
MANUNITEDFANFOREVER
"Cal Bear '66" <xxx@xxx.org> skrev i melding
news:eCvtWVq2HHA.2752@TK2MSFTNGP06.phx.gbl...
> GO BEARS!
>> on,
>> the
>> suggestions.
>> Rob
>>> very
>>> Taskbar
>>> are
>>> GO BEARS!
>>> > the same
>>> > Rob
>>> >> control
>>> >> setting
>>> >> Doug
>>> >> > can't get
>>> >> > any
>>> >> > get
>>> >> > sound
>>> >> > have
>>> >> > Rob
Old 08-13-2007   #8 (permalink)
rbwillm
Guest
I'm just using the motherboard audio & vista installed the drivers for that.
Rob
> GO BEARS!
> > suggestions.
> > Rob
> >> Taskbar
> >> GO BEARS!
> >> > same
> >> > Rob
> >> >> control
> >> >> Doug
> >> >> > any
> >> >> > sound
> >> >> > Rob
Old 08-13-2007   #9 (permalink)
rbwillm
Guest
Hi Lisbeth, I checked the sounds setting under sounds in control panel &
everything looks to be enabled, you can select or changed them & even play
them but can't hear them.
Rob
> MANUNITEDFANFOREVER
> > GO BEARS!
> >> on,
> >> the
> >> suggestions.
> >> Rob
> >>> very
> >>> Taskbar
> >>> are
> >>> GO BEARS!
> >>> > the same
> >>> > Rob
> >>> >> control
> >>> >> setting
> >>> >> Doug
> >>> >> > can't get
> >>> >> > any
> >>> >> > get
> >>> >> > sound
> >>> >> > have
> >>> >> > Rob
Old 08-13-2007   #10 (permalink)
Cal Bear '66
Guest
Go to Control Panel > Device Manager > expand Sound, video and game controllers.
The audio adapter will be listed there (Realtek, Sigma Tel, etc.)
GO BEARS!
news:AC4519F8-1929-4C38-9728-B09F9A9AEA79@microsoft.com...
> Rob
>> GO BEARS!
>> > on,
>> > the
>> > suggestions.
>> > Rob
>> >> very
>> >> Taskbar
>> >> are
>> >> GO BEARS!
>> >> > same
>> >> > Rob
>> >> >> control
>> >> >> setting
>> >> >> Doug
>> >> >> > get
>> >> >> > any
>> >> >> > sound
>> >> >> > have
>> >> >> > Rob
Display Modes
hard disk making a strange clicking sound dellbox Vista hardware & devices 1 06-25-2008 04:43 PM
Strange sound problem Daniel Vista General 2 06-21-2008 01:34 PM
Strange sound bites KRWstyle Vista General 3 08-05-2007 12:43 PM
Strange sound driver problem Walter Docherty Vista hardware & devices 0 06-21-2006 01:01 AM
strange happenings with Sound Barry & Melissa Vista hardware & devices 0 06-18-2006 06:31 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53
