Vista Tutorial - Problems with USB ports
Old 08-06-2007   #1 (permalink)
Mato
Guest
I have Intel motherboard DP965LT. The problem is with usb keys! If a plug it
in the usb port nothing happends! In Device manager it only shows unknow
device! I have downloaded the drivers from intel site but it didn't help. It
doesn't show any problems in the device manager. Just shows unknow device !
Can u please help me ? The problems is in Vista or in the motherboard ?
Old 08-06-2007   #2 (permalink)
Richard Urban
Guest
Re: Problems with USB ports
Front M/B ports are known to be problematical. If this is what you are using
for convenience, try a rear port.
Regards,
Richard Urban
"Mato" <Mato@discussions.microsoft.com> wrote in message
news:BFA84E42-37A7-45CA-A31F-059AE9488B14@microsoft.com...
>it
> It
Old 08-06-2007   #3 (permalink)
Mato
Guest
> Regards,
> Richard Urban
> >it
> > It
> The problem is the same with front and rear ports
Serial Ports, Com Ports and USB Vista hardware & devices
Still problems with USB ports not working Vista General
Showing Com Ports and Bluetooth Problems Vista hardware & devices
USB ports help! PLEASE! Vista hardware & devices
USB Ports Vista hardware & devices
