| Welcome to Windows Vista Forums. Our forum is dedicated to helping you find solutions with any problems, errors or issues you are experiencing with Windows Vista. The Vista forum also covers news and updates and has an extensive Vista tutorial section that covers a wide range of tips and tricks. |
| | LinkBack | Thread Tools | Display Modes |
| Guest | Problem Installing HP Printer on Vista Hi I am having some problems installing a HP Deskjet 5940 under Windows Vista. I have run the install file for Windows Vista which I downloaded from the HP website this Installs the driver and some other HP software OK but it gets stuck at 96% and won't go any further so I have to restart my computer to exit the setup. When the computer restarts I can print documents ok but when I got to access the HP Solution Centre to change some settings. I get the following error message "No HP devices have been detected. Solution Center will close now.". I have contacted HP about this issue and was told several methods of installing drivers which didn't solve the problem. There latest solution now has been to shift the blame to Microsoft and tell me to contact them. I don't belive it is a Microsoft problem but thought I should check on here to make sure and then I can get back to HP about it. Does anyone know a way of fixing this so that I can access the HP Solution Center? Thanks Craig |
| Guest | RE: Problem Installing HP Printer on Vista I'm having this same issue as well on the HP L7580 and HP was not able to assist. It demonstrated similar symptom as yours. "cplummer" wrote: > Hi > > I am having some problems installing a HP Deskjet 5940 under Windows Vista. > I have run the install file for Windows Vista which I downloaded from the HP > website this Installs the driver and some other HP software OK but it gets > stuck at 96% and won't go any further so I have to restart my computer to > exit the setup. > > When the computer restarts I can print documents ok but when I got to access > the HP Solution Centre to change some settings. I get the following error > message "No HP devices have been detected. Solution Center will close now.". > I have contacted HP about this issue and was told several methods of > installing drivers which didn't solve the problem. There latest solution now > has been to shift the blame to Microsoft and tell me to contact them. I don't > belive it is a Microsoft problem but thought I should check on here to make > sure and then I can get back to HP about it. > > Does anyone know a way of fixing this so that I can access the HP Solution > Center? > > Thanks > Craig |
| Newbie | Re: Problem Installing HP Printer on Vista |
| | #4 (permalink) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Guest | Re: Problem Installing HP Printer on Vista Hi I had the same problem with HP L7580, HP help was no HELP. I then did a manual uninstall with the batch utility in HP CD under utils
User>> Software>> HP and also delete HP files & folders under C:\ Users
Then do a reinstall as per procedure it works. In case the installation still stalls do a reboot. Pls note you should be logged in as Administatror other wise it does not work. It seems that the HP uninstaller leaves some entries that interfere with the new installation You are playing with the registry do take a back up. At your own risk. -- Uday "cgarner@xxxxxx" wrote:
My System Specs![]() | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Newbie | Re: Problem Installing HP Printer on Vista I am having the same problem with officejet pro L7580. Ran through many fixes with hp but nothing solves the problem. Please let me know if you find a solution. Thanks Sandy protemp@cogeco.ca |
| | #6 (permalink) | ||||||||||||||||||||||||
| Guest | Re: Problem Installing HP Printer on Vista Try installing in compatability mode for xp sp2 On Sun, 11 Nov 2007 22:57:33 -0600, protemp@xxxxxx <protempcogeco.ca.2zx5mi@xxxxxx-mx.forums.net> wrote:
| | #7 (permalink) | ||||||||||||||||||||||||||||||||||||
| Guest | Re: Problem Installing HP Printer on Vista Did you uninstall what you already had installed(The wrong HP Driver), before installing the new vista compatible downloaded driver? And redo the whole installation process with the printer, whether it is printer first, driver software second, or the other way around . And if you have a problem installing the printers drivers setup.exe, right-click on it>run as Admin. hope it helps. "Black Baptist" wrote:
| | #8 (permalink) | ||||||||||||||||||||||||||||||||||||
| Guest | Re: Problem Installing HP Printer on Vista Also it's SOP with HP printers to disconnect power and usb cables from your printer before installing the software and drivers. If you don't, the installation could well fail. Paul Riemerman "Black Baptist" <pray@xxxxxx> wrote in message news:664tq3h3tihlktgrftj15711lnhburh5kv@xxxxxx
| | #9 (permalink) | ||||||||||||||||||||||||||||||||||||
| Guest | Re: Problem Installing HP Printer on Vista ive tried downloading it from the site, and using the installation cd, AND letting windows find a driver/solution, there seems to BE NO correct driver for HP deskjets for vista! HP says its a vista problem, and microsoft tells me its an HP problem! should i just go return the damn printer?! "Mick Murphy" wrote:
| | #10 (permalink) | ||||||||||||||||||||||||||||||||||||
| Guest | Re: Problem Installing HP Printer on Vista Which HP Deskjet? "anarchypark" <anarchypark@xxxxxx> wrote in message news:A832F456-80E8-42E8-94F1-3CE4D20C63E1@xxxxxx
| Display Modes | |
| Problem installing Canon printer in Vista Ultimate 64 bit | Stephen Flanagan | Vista print fax & scan | 4 | 10-13-2008 02:25 AM |
| Problem Installing Printer Driver | pgonza02 | Vista hardware & devices | 5 | 08-31-2008 03:02 PM |
| Problem installing printer | alokyadav12 | Vista print fax & scan | 8 | 05-16-2008 03:10 PM |
| installing hp 8180 (wireless) printer to vista | Mac | Vista print fax & scan | 0 | 12-29-2007 11:35 AM |
| Creating new Printer-Port and installing new Printer | Jens Schulze | PowerShell | 3 | 10-11-2006 02:18 PM |
