Vista - more usb problems
Old 08-07-2007   #1 (permalink)
tbgjlb
more usb problems
I have been having problems with new and already installed usb devices
recently, the new one ( xbox 360 controllers ) just won't work, I have tried
everything and still can't seem to get them to work and they won't even get
recognised in "game controllers" in control panel.
the already installed devices stopped working ( belkin bluetooth dongle, old
gamepad ) but the mouse seems ok so far.
I have noticed there seems to be some issues on this message board with
usb's and some solutions with the hot fixes, my problem is I am not sure
which one to use as I have never used a hot fix in the past and was hoping
you guy's could point me in the right direction. Also these hot fixes do
they really work and if I install the wrong ones what kind of harm can they
cause.
thanks for any help
Old 08-07-2007   #2 (permalink)
Cal Bear '66
Re: more usb problems
I have read in various sources that next Tuesday's Windows Update will include
USB fixes. Perhaps you should wait a little before you try the hotfixes.
I Bleed Blue and Gold
GO BEARS!
"tbgjlb" <tbgjlb@discussions.microsoft.com> wrote in message
news:1D1C8805-670A-48C4-975B-6C0FA09D954D@microsoft.com...
> cause.
> thanks for any help
Old 08-08-2007   #3 (permalink)
tbgjlb
RE: more usb problems
thanks for that , I will wait for the update then.
> the alreahendy installed devices stopped working ( belkin bluetooth dongle, old
> cause.
> thanks for any help
Big vista problems need help icon/background/graphics/personalise problems Vista performance & maintenance
laptop start up problems and problems in general General Discussion
Problems starting command prompt on cygwin on vista ultimate, problems not had on Win2k3SP2 Vista General
2 different vista problems. Memory dump crash and startup repair cannot fix problems Vista General
Downgrading from 64bit Vista to 32bit, Media Center problems, web page printing problems Vista installation & setup
