| Guest | No Sound I just got this new computer and the Vista program and I've connected everything and I can not get the sound to work. I've double checked everything, could someone please let me know what it might be? Thanks |
| Guest | Re: No Sound First, do you have a red X on the Speaker icon in the Notification Area of the Taskbar? If you do, then your audio adapter is not properly installed and you need to install the proper Vista drivers. If there is no red X and in Control Panel (Classic view) > Device Manager > Sound, video and game controllers there are no red Xs or yellow exclamation points for your audio adapter, then right click on the Speaker icon in the Notification Area and select Playback Devices. In an empty area of the Playback Devices window, right click and check both "Show Disabled Devices" and "Show Disconnected Devices". Highlight Speakers and press the Set Default button. Use the Properties and Configure buttons to set up your speakers. While you are there, use the Sounds tab to test your speakers. If you are using a SPDIF (digital) connection to your speakers, set SPDIF as the default and enable SPDIF output in your sound card's audio manager application software. -- I Bleed Blue and Gold GO BEARS! "Seaglasser" <Seaglasser@discussions.microsoft.com> wrote in message news:0251F512-5276-4F79-9764-610BCD76028F@microsoft.com... >I just got this new computer and the Vista program and I've connected > everything and I can not get the sound to work. I've double checked > everything, could someone please let me know what it might be? > > Thanks |
| distorted sound in vista/createiv x-fi titanium sound card | Sound & Audio | |||
No sound when playing music or video, but internet sound works fine | Sound & Audio | |||
| Setting per Application Sound Output, or Per Sound Type Outputs... | Vista General | |||
| My Creative Sound Blaster X-FI Sound Card Works Now with Creative's RC1 Device Driver's! I Have Sound! | Vista General | |||
| Vista x64 RC2 - Sound Card/Amplifier - DTS Test Sound (Audigy 2 ZS SPDIF) | Vista General | |||
