| | Ipod, USB Flash Drive Drivers Not Found I have a 60Gb 5th generation ipod and several usb flash drives that used to be recognized by Windows XP's native Plug and Play driver scheme. However, after a clean install of Vista Ultimate 32-bit, Windows is unable to find drivers for any of my devices. I have followed other discussions and tried things such as leaving devices plugged in and rebooting, directing Windows to search for drivers in the C:\Windows folder, installing updates from Windows Update, and other attempts. I am at the end of my creativity about getting my ipod and flash drives to install so that I can use them. Having tried previous suggestions, I'm stumped. Any ideas? Has Microsoft basically dropped plug and play support in Vista? This would be an odd move, as these devices are so widespread... |
| | RE: Ipod, USB Flash Drive Drivers Not Found I am having exactly the same issue with USB Flash Drives. I have several -- some install and others don't. Vista cannot find the drivers anywhere for the problem drives and neither can I. All the drives work fine on my XP based laptop. "Pi" wrote: > I have a 60Gb 5th generation ipod and several usb flash drives that used to > be recognized by Windows XP's native Plug and Play driver scheme. However, > after a clean install of Vista Ultimate 32-bit, Windows is unable to find > drivers for any of my devices. I have followed other discussions and tried > things such as leaving devices plugged in and rebooting, directing Windows to > search for drivers in the C:\Windows folder, installing updates from Windows > Update, and other attempts. I am at the end of my creativity about getting > my ipod and flash drives to install so that I can use them. Having tried > previous suggestions, I'm stumped. Any ideas? Has Microsoft basically > dropped plug and play support in Vista? This would be an odd move, as these > devices are so widespread... |
| | Re: Ipod, USB Flash Drive Drivers Not Found This solution has worked for some people with problematic USB devices: Locate the file INFCACHE.1 in C:\Windows\inf Right click on the INFCACHE.1 file, select Properties >Security > Edit, and give your account full control. Delete INFCACHE.1, or rename it to INFCACHE.1.BAK or temporarily move to your desktop. REBOOT Try plugging in your USB devices again. -- I Bleed Blue and Gold GO BEARS! "SandyG" <SandyG@discussions.microsoft.com> wrote in message news:CE0B9ED6-27B6-4601-8A9F-F8572E4BF114@microsoft.com... >I am having exactly the same issue with USB Flash Drives. I have several -- > some install and others don't. Vista cannot find the drivers anywhere for the > problem drives and neither can I. All the drives work fine on my XP based > laptop. > > "Pi" wrote: > >> I have a 60Gb 5th generation ipod and several usb flash drives that used to >> be recognized by Windows XP's native Plug and Play driver scheme. However, >> after a clean install of Vista Ultimate 32-bit, Windows is unable to find >> drivers for any of my devices. I have followed other discussions and tried >> things such as leaving devices plugged in and rebooting, directing Windows to >> search for drivers in the C:\Windows folder, installing updates from Windows >> Update, and other attempts. I am at the end of my creativity about getting >> my ipod and flash drives to install so that I can use them. Having tried >> previous suggestions, I'm stumped. Any ideas? Has Microsoft basically >> dropped plug and play support in Vista? This would be an odd move, as these >> devices are so widespread... |
| | Re: Ipod, USB Flash Drive Drivers Not Found Thank you very much Cal Bear '66. Your tip sounds like it could have worked for me. Hopefully it will be helpful to others also. Meanwhile, I got fed up and ran a reinstall (upgrade) of Vista Ultimate 32 with all of my devices plugged in. After the upgrade finished, the devices were recognized and installed as normal. This fixed the issues for my 60Gb ipod and usb flash drives. All of my files and programs of course are still intact, so I would recommend this solution to any other people who are having persistent usb problems. It'll take about an hour, but for whatever reason it fixed my problem. Thanks to all who posted replies here. I can't help thinking that Microsoft really needs to fix this issue, because loads of people seem to be experiencing it in different forms. Tom "Cal Bear '66" wrote: > This solution has worked for some people with problematic USB devices: > > Locate the file INFCACHE.1 in C:\Windows\inf > > Right click on the INFCACHE.1 file, select Properties >Security > Edit, and give > your account full control. > > Delete INFCACHE.1, or rename it to INFCACHE.1.BAK or temporarily move to your > desktop. > > REBOOT > > Try plugging in your USB devices again. > > > -- > I Bleed Blue and Gold > GO BEARS! > > > "SandyG" <SandyG@discussions.microsoft.com> wrote in message > news:CE0B9ED6-27B6-4601-8A9F-F8572E4BF114@microsoft.com... > >I am having exactly the same issue with USB Flash Drives. I have several -- > > some install and others don't. Vista cannot find the drivers anywhere for the > > problem drives and neither can I. All the drives work fine on my XP based > > laptop. > > > > "Pi" wrote: > > > >> I have a 60Gb 5th generation ipod and several usb flash drives that used to > >> be recognized by Windows XP's native Plug and Play driver scheme. However, > >> after a clean install of Vista Ultimate 32-bit, Windows is unable to find > >> drivers for any of my devices. I have followed other discussions and tried > >> things such as leaving devices plugged in and rebooting, directing Windows to > >> search for drivers in the C:\Windows folder, installing updates from Windows > >> Update, and other attempts. I am at the end of my creativity about getting > >> my ipod and flash drives to install so that I can use them. Having tried > >> previous suggestions, I'm stumped. Any ideas? Has Microsoft basically > >> dropped plug and play support in Vista? This would be an odd move, as these > >> devices are so widespread... > > > |
| | Re: Ipod, USB Flash Drive Drivers Not Found Thanks, Cal Bear '66. Your solution worked and coincidentally solved a driveer problem I was having with an Epson scanner. I notice that INFCACHE.1 has not been regenerated. If it is not necessary and it causes driver problems, you would think that Microsoft would eliminate it or fix the problem. All the best. "Cal Bear '66" wrote: > This solution has worked for some people with problematic USB devices: > > Locate the file INFCACHE.1 in C:\Windows\inf > > Right click on the INFCACHE.1 file, select Properties >Security > Edit, and give > your account full control. > > Delete INFCACHE.1, or rename it to INFCACHE.1.BAK or temporarily move to your > desktop. > > REBOOT > > Try plugging in your USB devices again. > > > -- > I Bleed Blue and Gold > GO BEARS! > > > "SandyG" <SandyG@discussions.microsoft.com> wrote in message > news:CE0B9ED6-27B6-4601-8A9F-F8572E4BF114@microsoft.com... > >I am having exactly the same issue with USB Flash Drives. I have several -- > > some install and others don't. Vista cannot find the drivers anywhere for the > > problem drives and neither can I. All the drives work fine on my XP based > > laptop. > > > > "Pi" wrote: > > > >> I have a 60Gb 5th generation ipod and several usb flash drives that used to > >> be recognized by Windows XP's native Plug and Play driver scheme. However, > >> after a clean install of Vista Ultimate 32-bit, Windows is unable to find > >> drivers for any of my devices. I have followed other discussions and tried > >> things such as leaving devices plugged in and rebooting, directing Windows to > >> search for drivers in the C:\Windows folder, installing updates from Windows > >> Update, and other attempts. I am at the end of my creativity about getting > >> my ipod and flash drives to install so that I can use them. Having tried > >> previous suggestions, I'm stumped. Any ideas? Has Microsoft basically > >> dropped plug and play support in Vista? This would be an odd move, as these > >> devices are so widespread... > > > |
| | #6 (permalink) |
| | Re: Ipod, USB Flash Drive Drivers Not Found You're welcome. Glad you solved your problem(s). The INFCACHE.1 problem only seems to happen on a relatively few users. Luckily I have not had this problem. -- I Bleed Blue and Gold GO BEARS! "SandyG" <SandyG@discussions.microsoft.com> wrote in message news:8F618F1F-2978-49E2-A8D6-F3F768D2DB1C@microsoft.com... > Thanks, Cal Bear '66. Your solution worked and coincidentally solved a > driveer problem I was having with an Epson scanner. > > I notice that INFCACHE.1 has not been regenerated. If it is not necessary > and it causes driver problems, you would think that Microsoft would eliminate > it or fix the problem. > > All the best. > > "Cal Bear '66" wrote: > >> This solution has worked for some people with problematic USB devices: >> >> Locate the file INFCACHE.1 in C:\Windows\inf >> >> Right click on the INFCACHE.1 file, select Properties >Security > Edit, and >> give >> your account full control. >> >> Delete INFCACHE.1, or rename it to INFCACHE.1.BAK or temporarily move to your >> desktop. >> >> REBOOT >> >> Try plugging in your USB devices again. >> >> >> -- >> I Bleed Blue and Gold >> GO BEARS! >> >> >> "SandyG" <SandyG@discussions.microsoft.com> wrote in message >> news:CE0B9ED6-27B6-4601-8A9F-F8572E4BF114@microsoft.com... >> >I am having exactly the same issue with USB Flash Drives. I have several -- >> > some install and others don't. Vista cannot find the drivers anywhere for >> > the >> > problem drives and neither can I. All the drives work fine on my XP based >> > laptop. >> > >> > "Pi" wrote: >> > >> >> I have a 60Gb 5th generation ipod and several usb flash drives that used >> >> to >> >> be recognized by Windows XP's native Plug and Play driver scheme. >> >> However, >> >> after a clean install of Vista Ultimate 32-bit, Windows is unable to find >> >> drivers for any of my devices. I have followed other discussions and >> >> tried >> >> things such as leaving devices plugged in and rebooting, directing Windows >> >> to >> >> search for drivers in the C:\Windows folder, installing updates from >> >> Windows >> >> Update, and other attempts. I am at the end of my creativity about >> >> getting >> >> my ipod and flash drives to install so that I can use them. Having tried >> >> previous suggestions, I'm stumped. Any ideas? Has Microsoft basically >> >> dropped plug and play support in Vista? This would be an odd move, as >> >> these >> >> devices are so widespread... >> >> >> |
| | #7 (permalink) |
| | Re: Ipod, USB Flash Drive Drivers Not Found Guess I'm another of the 'relatively few'... I had Vista up and working, and a nice Patriot 2GB usb drive with ReadyBoost humming along...then for some crazy reason I decided to upgrade my CPU and memory (Athlon 64 3800+ to Athlon 64 x2 5200+, 2GB DDR to 2GB DDR2) and that's working well with a noticeable improvement in boot-up and reduction in overall CPU usage...but Vista doesn't like my USB drive any more. I tried renaming INFCACHE.1 to INFCACHE1.bak and rebooting - no change. I tried moving it out of the INF folder - no change. My other USB stuff (mouse, keyboard, printer, other non-readyboost USB drives) work fine. Any ideas, please? |
| Exception Processing Message when attaching ipod & USB flash drive | Vista hardware & devices | |||
| Ipod, USB Flash Drive Drivers Not Found | Vista hardware & devices | |||
| Integral 4Gb ENVOY plus USB Flash drive Vista Business Drivers | Vista hardware & devices | |||
| 1 gb Flash Drive (USB and SD) -- no drivers found | Vista General | |||
| Cannot load drivers from USB flash drive | Vista installation & setup | |||
