Disk Management 'System Drive' Issue
  1. #1
    Saerain Guest
    I have one 500 GB drive in three partitions: C, D, and E. I am attempting to
    delete D (which is empty) in Disk Management, so that I may extend C (where
    Vista is located) into it. However, D, for whatever reason, is marked
    'System', while C is marked only as 'Boot, Page File, Active, Crash Dump'.
    What can I do to make C the 'System' partition? I thought this was determined
    solely by where the operating system was installed.
    Vista was once located on D, but D has long since been formatted and Vista
    reinstalled on C.
  2. #2
    Saerain Guest
    Re: Disk Management 'System Drive' Issue
    I had only formatted D (which had actually been E before installing Vista on
    what had been D relettered all three automatically).
    However, I was just a few hours ago able to do everything I needed to within
    the Vista installation disc from boot. My goal in all of this was to get back
    down to a single full-drive partition, and the installation disc allowed me
    to delete Partition 3, then Partition 2, extend Partition 1 to encompass the
    drive, then install Vista.
    This did result in me doing something that I wanted to avoid: installing the
    operating system somewhere other than the centre of the drive. I honestly do
    not know how much this will affect anything, but I will try to rearrange it
    later.
    "bob t" wrote:
    > I am noticing wierd behavior with a drive and am wondering if hardware info
    > is stored on C: I had a Vista Installation on I: when I had a Linux install
    > on D: I formatted I: to reinstall Vista after never getting my graphics
    > card to work correctly (Nvidia 5200) but before installing Vista, I ran XP
    > setup and deleted the D: etx3 partition and formatted NTFS in case the ext3
    > file system was hanging something in Vista. Now D: is never mounted unless
    > I ask Device Manager to detect hardware changes. I install the drivers, the
    > correct drivers, and every bootup D: is not mounted so I was wondering if
    > there was some file on C: from install #1 that never got overwritten and now
    > I see your problem with Windows thinking systemroot is on D: So when you
    > deleted D: did you also format C: ? I would hate to format C: because I
    > have Windows 2000 and XP also installed but I am also thinking that I will
    > have to to get Windows Vista working,
    > "Saerain" <Saerain@discussions.microsoft.com> wrote in message
    > news:8AEBAF68-7A19-4F8B-9969-150D386E75EB@microsoft.com...
    > >to
    > > (where
    > > determined
    > > reinstalled on C.
  3. #3
    bob t Guest
    >to
    > (where
    > determined
    > reinstalled on C.
Disk Management 'System Drive' Issue problems?
Can't initialize drive in Disk Management kunapen General Discussion 0 03 Mar 2010
Cannot change drive letter via Disk management Krakapo Vista hardware & devices 2 04 Aug 2009
Partition drive by shrinking in Disk management microsofthater General Discussion 2 07 May 2009
Flash Drive has no drive letter... Not in Disk Management mattperry Vista hardware & devices 12 13 Jan 2009
Issues with System drive in Disk Management on a Dual Boot system =?Utf-8?B?dGhpbHRvbg==?= Vista General 4 09 Jul 2006
