Vista - External Hard Drive Not Working
Old 06-26-2006   #1 (permalink)
ironj221
I have an external hard drive by Smart Drive. It turned out to be the entire
root of all my problems while installing Vista. Whenever I turn it on,
everything locks up in Vista. When it's off, everything is fine.
The only conflict in the device manage is a "PCI Modem". I do not have a
56k modem on this computer, so I'm not sure what that is.
Help would be appreciated, thank you.
Old 06-27-2006   #2 (permalink)
Aaron C
RE: External Hard Drive Not Working
same here, whenever I put in an external usb drive it hangs or slows down. it
is a western digital 80GB drive...
Old 06-27-2006   #3 (permalink)
ironj221
I'm havn't found a solution yet, let me know if you do.
Old 08-27-2006   #4 (permalink)
=?Utf-8?B?ZHNtdHVyYm8=?=
Having same problem with an external USB hard drive enclosure. It is very
strange, Vista won't boot if it is turned on, however it was on when I
installed Vista.
If I turn it on while in Vista, I get the clunk/clunk device detected sound
but it never shows up.
External USB Hard Drive not working, Vista asking fordrivers Vista hardware & devices
My 500gb sumodisk external hard drive isn't working anyway. Vista hardware & devices
External Hard-drive not working Vista hardware & devices
Anyone has a working External Hard Drive? Vista hardware & devices
external hard drive not working Vista hardware & devices
