| Welcome to Windows Vista Forums. Our forum is dedicated to helping you find solutions with any problems, errors or issues you are experiencing with Windows Vista. The Vista forum also covers news and updates and has an extensive Vista tutorial section that covers a wide range of tips and tricks. |
| | LinkBack | Thread Tools | Display Modes |
| Guest | LG-8500 (Chocolate) Device Connection Error I loaded the Vista compliant device drivers for the LG-8500 cell phone and phone connected to USB port. Says device drivers installed correctly and it appears to connect, but when I start sync process with V Cast Music Manager, I get error box saying device un-plugged, new error box comes up and says "windows needs to install driver", and then gives an error that "driver not installed correctly". Device manager looks like it sees it. Have talked with Tech and they say it is a Vista issue. Any help out there? |
| Display Modes | |
| just purchased GeForce 8500 gt card | hatehereyes | Graphic cards | 7 | 09-19-2008 01:48 AM |
| Brother MFC-8500 Driver | SteveC | Vista print fax & scan | 0 | 10-15-2007 12:51 PM |
| chocolate fire guard... | Rob Eventine | Vista General | 14 | 03-25-2007 10:15 PM |
| Vista Can Chocolate | =?Utf-8?B?T3BlWHA=?= | Vista music pictures video | 0 | 09-25-2006 11:48 PM |
| Chocolate And WMP11beta | =?Utf-8?B?T3BlWHA=?= | Vista General | 3 | 09-25-2006 08:37 PM |
