System wont recognize DVD drive
  1. #1
    Sensei5 Guest
    I had a problem with my DVD drive. The system would not recognize it after
    ripping a CD into iTunes. I took the laptop to the Geek Squad and they ran a
    utility that reset some kind of registry hook that some programs install when
    they use the DVD drive. I am trying to find that utility so I don't have to
    go back to the Geek Squad again even though they were very gracious and did
    not charge me for the assist. Does anyone know where I can get this?
  2. #2
    Newbie
    Vista Home Premium 32bit
    Local Time: 04:24 AM
    Re: System wont recognize DVD drive
    Nothing like a "late" response... If anyone happens to read this thread, I have had problems with Vista Home Premium not recognizing my DVD/RW drive. I had searched the net for help by reading many forums, and I found a successful fix!
    My computer is 2 months new, dual core, 350gb h/d 3 gb RAM yadda, yadda, yadda... a nice Gateway. Anyway, I bought and installed Print Shop 22, searches yielded unfortunate results... They said the program was not compatible with Vista. I decided to try anyway, at the end of the install, the program stated that the program was incompatible with Vista.... I continued.
    The program has run fine with zero problems, BUT, after install, my computer will not recognize my DVD/RW! I restored back to a point before loading the Print Shop 22 software. Viola! My DVD drive is back up... I reloaded the Print Shop 22 software and 48 hours later the DVD is not recognized again. Okay long story, short... The fix is, open up regedit, find...
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
    Open it and find the line the specifies an "upper filter" and/or "lower filter" and delete them! reboot and see what comes of it... It worked for me and still does, good luck!
  3. #3
    Newbie
    Vista 32bit
    THANK YOU!
    I've been searching for weeks for a fix. My ASUS DVD-ROM drive works fine in XP 64bit, but Vista 32bit would not recognize it. Editing the registry as you described, (and rebooting) allowed Vista to recognize my DVD drive.
HELP!! vista wont recognize my new hard drive frelancr42 General Discussion 5 22 Jul 2009
wont recognize passwd or address in windows mail Andy Vista mail 0 29 Oct 2008
TV wont recognize PC Txsbigfoot Vista music pictures video 1 03 Jul 2008
Vista wont recognize my wireless network Hobbes Vista networking & sharing 2 23 Sep 2007
After Hibernate Vista wont recognize LAN Fluffyjr2 Vista networking & sharing 13 27 Aug 2007
