Vista Business 32 bit and HP DVD Writer model dvd640ri
  1. #1
    Lowteknate@gmail.com Guest
    Hello,
    I have the HP DVD writer 640ri. It worked flawlessly in XP SP2. When
    I got a new PC with Vista Business ( Acerpower FH with P4 HT 3.0 GHz,
    1 GB RAM) I decided to swap the writer they had in it for mone. The
    DVD writer they had in was probably fine but I always liked mine.
    Install went ok. When I booted up everything was ok. When I put a CD
    (or DVD) in the drive never spins up as far as I can tell. The PC
    locks up TIGHT. I have to do a cold boot. If I leave the disc in the
    PC locks up on the Windows splash screen. But again if there is no
    disc everything is good.
    If I put my Partition Magic CD in and boot to it it works great. I
    even decided that since I just got the PC and I had not installed
    anything myself as far as software and I really wanted to keep my HP
    writer in it that I would take the Complete System restore DVD I made
    (before I swapped the drives) and just see if it would boot to it and
    restore the system. So it booted to that DVD fine and re-installed
    from scratch. So the drive works.
    Vista and the 640ri don't play nice. At least not for me.
    I decided to put the original writer back in. When I do I search for
    640ri + vista + HP I get no results in Google. When I leave the "ri"
    out I get results but I don't see anything about my issue. mostly 640
    GB hard drives.
    Any ideas?
  2. #2
    Carey Frisch [MVP] Guest
    Re: Vista Business 32 bit and HP DVD Writer model dvd640ri
    Probably the cable to your DVD drive is defective
    or is not fully seated .... try a new cable.
    Carey Frisch
    Microsoft MVP
    Windows Shell/User
    <Lowteknate@gmail.com> wrote in message news:1187293598.849737.26900@z24g2000prh.googlegroups.com...
    Hello,
    GB hard drives.
    Any ideas?
  3. #3
    Cari \(MS-MVP\) Guest
    Along with Carey's suggestions, check the jumpers at the rear of the drive.
    Cari (MS-MVP)
    Windows Technologies - Printing & Imaging
    http://www.coribright.com/windows
    > Hello,
    > GB hard drives.
    > Any ideas?
  4. #4
    Cari (MS-MVP)
    > Hello,
    > GB hard drives.
    > Any ideas?
Vista Business 32 bit and HP DVD Writer model dvd640ri problems?
Current model joystick for Vista x64 Qu0ll Gaming 3 27 Feb 2008
dvd writer no longer recognised as writer willem Vista hardware & devices 3 28 Feb 2007
Strong host model in Vista imanandr Vista networking & sharing 1 24 Nov 2006
Problem with HP DVD Writer 740b DVD Writer GWC Vista hardware & devices 0 23 Jun 2006
Vista and the Bell-Padula Model pestocat Vista security 5 20 May 2006
