Vista - "Intel(R) PRO/Wireless 3945ABG Network Connection" driver installa
Old 08-17-2007   #1 (permalink)
Quantum Mechanic
I got a message from vista saying that the previous driver of this device had
caused a problem. I downloaded the new driver but for some reason Intel
doesn't support home users installing these drivers (probably washing their
hands of responsibility for possible problems with their installation
software) and this driver is not self extracting or installing and is just
composed of .zip files.
I would greatly appreciate it if someone helped me install this driver.
yours
troubled windows vista user
Old 08-17-2007   #2 (permalink)
David B.
Re: "Intel(R) PRO/Wireless 3945ABG Network Connection" driver installa
Unzip the driver, go to the nic in device manager, right click and select
update driver, point the wizard to the directory of the unzipped files.
Crosspost, do not multipost http://www.blakjak.demon.co.uk/mul_crss.htm
How to ask a question http://support.microsoft.com/kb/555375
How to Post http://www.dts-l.org/goodpost.htm
_________________________________________________________________________________
"Quantum Mechanic" <Quantum Mechanic@discussions.microsoft.com> wrote in
message news:77AF7240-4DB7-4C34-AE14-A2382264DDCC@microsoft.com...
>had
> their
> yours
Old 08-17-2007   #3 (permalink)
Quantum Mechanic
thanks m8, problem solved
Mechanic
> >had
> > their
> > yours
NetworkStumbler, HP DV9000 series. Intel Pro Wireless 3945ABG Vista hardware & devices
Can't connect using INTEL(R) PRO/WIRELESS 3945ABG Vista networking & sharing
Wireless Network Problems since upgrade to vista Via Intel 3945ABG Vista General
Can't connect using INTEL(R) PRO/WIRELESS 3945ABG NETWORK CONNECTI Vista networking & sharing
Cannot get Intel Pro/100 VE Network or Pro/wireless 3945ABG to wor Vista hardware & devices
