| Guest | Making my DVD writer work again! My LG GSA-H50-L DVD writer has worked in the past on my Vista 64bit system, but has now decided not to work. I didn't do anything with the harware. The power is still connected, and if I disable all the drivers, vista recognizes the ATA device and attempts to install the drivers. At that point, it says it fails, and in device manager, it reports that it doesn't work because the drivers are missing or corrupted. No software comes with the drive b/c I thought it uses generic drivers. Is there somewhere I can download these generic drivers so that it can install them next time? |
| Guest | Re: Making my DVD writer work again! I have exact the same problem with 2 writers, NEC 3520 ATA and Samsung SN 308B Scsi. Both can suddenly not work, and i have tryed the same ad you, but with the same result. Help needed "Josh" <Josh@discussions.microsoft.com> skrev i meddelelsen news:49B9C029-2992-420E-96DB-756C06A38FB3@microsoft.com... > My LG GSA-H50-L DVD writer has worked in the past on my Vista 64bit > system, but has now decided not to work. I didn't do anything with the > harware. The power is still connected, and if I disable all the drivers, > vista recognizes the ATA device and attempts to install the drivers. At > that > point, it says it fails, and in device manager, it reports that it doesn't > work because the drivers are missing or corrupted. No software comes with > the > drive b/c I thought it uses generic drivers. Is there somewhere I can > download these generic drivers so that it can install them next time? |
| Guest | Re: Making my DVD writer work again! Try this: http://support.microsoft.com/kb/929461/en-us -- I Bleed Blue and Gold GO BEARS! "Knud Rasmussen" <kras@webspeed.dk> wrote in message news:84D174F7-2099-461C-9E48-509E8576589E@microsoft.com... >I have exact the same problem with 2 writers, NEC 3520 ATA and Samsung SN 308B >Scsi. Both can suddenly not work, and i have tryed the same ad you, but with >the same result. Help needed > > "Josh" <Josh@discussions.microsoft.com> skrev i meddelelsen > news:49B9C029-2992-420E-96DB-756C06A38FB3@microsoft.com... >> My LG GSA-H50-L DVD writer has worked in the past on my Vista 64bit >> system, but has now decided not to work. I didn't do anything with the >> harware. The power is still connected, and if I disable all the drivers, >> vista recognizes the ATA device and attempts to install the drivers. At that >> point, it says it fails, and in device manager, it reports that it doesn't >> work because the drivers are missing or corrupted. No software comes with the >> drive b/c I thought it uses generic drivers. Is there somewhere I can >> download these generic drivers so that it can install them next time? > |
| Guest | Re: Making my DVD writer work again! Thank you very much, itīs works "Cal Bear '66" <xxx@xxx.org> skrev i meddelelsen news:080BAED1-BD2F-4760-BA48-B5FBD7EFF061@microsoft.com... > Try this: > > http://support.microsoft.com/kb/929461/en-us > > -- > I Bleed Blue and Gold > GO BEARS! > > > "Knud Rasmussen" <kras@webspeed.dk> wrote in message > news:84D174F7-2099-461C-9E48-509E8576589E@microsoft.com... >>I have exact the same problem with 2 writers, NEC 3520 ATA and Samsung SN >>308B Scsi. Both can suddenly not work, and i have tryed the same ad you, >>but with the same result. Help needed >> >> "Josh" <Josh@discussions.microsoft.com> skrev i meddelelsen >> news:49B9C029-2992-420E-96DB-756C06A38FB3@microsoft.com... >>> My LG GSA-H50-L DVD writer has worked in the past on my Vista 64bit >>> system, but has now decided not to work. I didn't do anything with the >>> harware. The power is still connected, and if I disable all the drivers, >>> vista recognizes the ATA device and attempts to install the drivers. At >>> that >>> point, it says it fails, and in device manager, it reports that it >>> doesn't >>> work because the drivers are missing or corrupted. No software comes >>> with the >>> drive b/c I thought it uses generic drivers. Is there somewhere I can >>> download these generic drivers so that it can install them next time? >> > > |
| Guest | Re: Making my DVD writer work again! Nice! You're welcome. -- I Bleed Blue and Gold GO BEARS! "Knud Rasmussen" <kras@webspeed.dk> wrote in message news:7CCF1F32-7B3C-4AC5-8A60-98E81DCD700A@microsoft.com... > Thank you very much, itīs works > > "Cal Bear '66" <xxx@xxx.org> skrev i meddelelsen > news:080BAED1-BD2F-4760-BA48-B5FBD7EFF061@microsoft.com... >> Try this: >> >> http://support.microsoft.com/kb/929461/en-us >> >> -- >> I Bleed Blue and Gold >> GO BEARS! >> >> >> "Knud Rasmussen" <kras@webspeed.dk> wrote in message >> news:84D174F7-2099-461C-9E48-509E8576589E@microsoft.com... >>>I have exact the same problem with 2 writers, NEC 3520 ATA and Samsung SN >>>308B Scsi. Both can suddenly not work, and i have tryed the same ad you, but >>>with the same result. Help needed >>> >>> "Josh" <Josh@discussions.microsoft.com> skrev i meddelelsen >>> news:49B9C029-2992-420E-96DB-756C06A38FB3@microsoft.com... >>>> My LG GSA-H50-L DVD writer has worked in the past on my Vista 64bit >>>> system, but has now decided not to work. I didn't do anything with the >>>> harware. The power is still connected, and if I disable all the drivers, >>>> vista recognizes the ATA device and attempts to install the drivers. At >>>> that >>>> point, it says it fails, and in device manager, it reports that it doesn't >>>> work because the drivers are missing or corrupted. No software comes with >>>> the >>>> drive b/c I thought it uses generic drivers. Is there somewhere I can >>>> download these generic drivers so that it can install them next time? >>> >> >> > |
| Making 108Mbps work | Network & Sharing | |||
| making ALT tab work like MS WIndows key Tab? | Vista General | |||
| trouble setting a UDP and making it work in media player | Vista performance & maintenance | |||
| Making Remote Assist Work?? | Vista General | |||
