Battery Meter
  1. #1
    CJP89 Guest
    Battery Meter
    My battery meter shows the remaining power only as a percentage and not as a
    specific time (which is my preferred option). I am running Vista on a Toshiba
    laptop. Is there a way to fix this in Vista or is it part of the laptops
    design?
  2. #2
    JW Guest
    Re: Battery Meter
    The remaining time on a battery is a direct function of the workload being
    placed on the PC. For example if you are using the Laptop to watch DVD
    movies that remaining time will be one heck of a list then if you are just
    working on a document or a spreadsheet.
    And since this is not constant there is now way for Vista to estimate it.
    "CJP89" <CJP89@discussions.microsoft.com> wrote in message
    news:1F06BF9A-DAA9-4134-ADF4-D321EB66F087@microsoft.com...
    > a
    > Toshiba
    > design?
  3. #3
    CJP89 Guest
    Re: Battery Meter
    I thought something was wrong because I know that XP laptops update to show
    the remaining time according to the stress on the system. Also I know some
    people that downloaded gadgets that did this for them on Vista, I have tried
    this and it still doesn't work. I was hoping that there would be some setting
    to fix this.
    > > a
    > > Toshiba
    > > design?
Battery Meter problems?
Battery Meter on task bar does not show Bob from down under Vista General 14 03 Nov 2009
Battery meter nhall2006 General Discussion 1 21 Apr 2009
Battery meter Battery Meter Vista General 2 27 May 2008
Battery Strength Meter Rick Rockett Vista installation & setup 5 12 Sep 2007
Battery meter Carrie Vista General 1 25 Jun 2007
