| | external hard drive not working Whenever my hard drive is connected via USB, windows Vista either hangs or runs very slowly. The hard drive is also not visible as a drive. I have seen a few other people report this as a problem and wondering if anyone has found a solution yet? The only conflict in the device manage is a "PCI Modem". I do not have a 56k modem on this computer, so I'm not sure what that is. Help would be appreciated, thank you. |
| | RE: external hard drive not working Try going to the drive's manufastureer site and get the latest driver you can find. Also try doing an firmware update (if applicable). "ironj221" wrote: > Whenever my hard drive is connected via USB, windows Vista either hangs or > runs very slowly. The hard drive is also not visible as a drive. I have > seen a few other people report this as a problem and wondering if anyone has > found a solution yet? > > The only conflict in the device manage is a "PCI Modem". I do not have a > 56k modem on this computer, so I'm not sure what that is. > > Help would be appreciated, thank you. |
| | RE: external hard drive not working USB is a bit flaky in this release. I would go to device manager, uninstall all usb devices and get Windows to reinstall to see if it fixes the problem. "tonyb" wrote: > Try going to the drive's manufastureer site and get the latest driver you can > find. Also try doing an firmware update (if applicable). > > "ironj221" wrote: > > > Whenever my hard drive is connected via USB, windows Vista either hangs or > > runs very slowly. The hard drive is also not visible as a drive. I have > > seen a few other people report this as a problem and wondering if anyone has > > found a solution yet? > > > > The only conflict in the device manage is a "PCI Modem". I do not have a > > 56k modem on this computer, so I'm not sure what that is. > > > > Help would be appreciated, thank you. |
| External USB Hard Drive not working, Vista asking fordrivers | Vista hardware & devices | |||
| My 500gb sumodisk external hard drive isn't working anyway. | Vista hardware & devices | |||
| External Hard-drive not working | Vista hardware & devices | |||
| External Hard Drive Not Working | Vista hardware & devices | |||
| Anyone has a working External Hard Drive? | Vista hardware & devices | |||
