| | CPU running at max when running programs I've just upgraded from XP to Vista Ultimate and seems that my processor is always running at max when i run or install programs (the fan noise is annoying). It also does the the same windows is installing updates. Is this normal? Do i need to upgrade CPU? My system: P4 3.0GHz, 2GB RAM, GeForce 8600GTS. |
| | Re: CPU running at max when running programs it would be normal to run at max during the initial start up to run a program, it should slow down once the program is running , unless it is a resource hog. installing updates takes a lot of resources. might be more helpful if you provide some names of programs that DO NOT allow the cpu to throttle back while they are running. mikeyhsd@xxxxxx "allblue" <allblue@xxxxxx> wrote in message news:FD18D8F6-65B8-4A8B-9DA8-E3F7B7E1C25E@xxxxxx I've just upgraded from XP to Vista Ultimate and seems that my processor is always running at max when i run or install programs (the fan noise is annoying). It also does the the same windows is installing updates. Is this normal? Do i need to upgrade CPU? My system: P4 3.0GHz, 2GB RAM, GeForce 8600GTS. |
| | Re: CPU running at max when running programs how do you know its running at max........have you opened task manager and looked or are you strictly going by the noise the fan makes?? peter "allblue" <allblue@xxxxxx> wrote in message news:FD18D8F6-65B8-4A8B-9DA8-E3F7B7E1C25E@xxxxxx Quote: > I've just upgraded from XP to Vista Ultimate and seems that my processor > is > always running at max when i run or install programs (the fan noise is > annoying). It also does the the same windows is installing updates. Is > this > normal? Do i need to upgrade CPU? > > My system: P4 3.0GHz, 2GB RAM, GeForce 8600GTS. |
| Running 32 bit Programs In Vista 64 bit? | General Discussion | |||
| Running old programs | Vista General | |||
| running xp programs on vista | Vista General | |||
| Programs/Applications running | Vista performance & maintenance | |||
| Running Programs | Vista General | |||
