| Guest | Bluetooth headset help Hi there, I have just recieved a pair of i-tech blueband headphones http://www.itechdynamic.com/en/produ...id=3&pid=03030 i have been trying to connect these to my hp notebook dv2166eu http://h10025.www1.hp.com/ewfrf/wc/p...s=2093&lang=en The notebook connects to them fine and pairs with it ok, when I click web links I can hear the clicking noises the IE makes when you click on links, but when I try to listen to music/online radio or anything like that, I hear nothing. I have tried to do some reasearch and it seems its something to do with a2dp profiles, and in this reaserch its something to do with the latest bluetooth drivers for vista home premium, so can anyone point me in the correct direction for the drivers to enable a2dp please, or even a hack or a fix to this problem, thanks very much. |
| Guest | Re: Bluetooth headset help In support go to sounds then check to see that you have to speakers systems. One is the normal speakers and the other is headphones, set the headphones as the default. This should allow it to work. "Garethm1976" <Garethm1976@xxxxxx> wrote in message news:81EA2BA3-D3E5-4582-AEB9-8291DB057CC5@xxxxxx Quote: > Hi there, > I have just recieved a pair of i-tech blueband headphones > > http://www.itechdynamic.com/en/produ...id=3&pid=03030 > > i have been trying to connect these to my hp notebook dv2166eu > > http://h10025.www1.hp.com/ewfrf/wc/p...s=2093&lang=en > > The notebook connects to them fine and pairs with it ok, when I click web > links I can hear the clicking noises the IE makes when you click on links, > but when I try to listen to music/online radio or anything like that, I > hear > nothing. > I have tried to do some reasearch and it seems its something to do > with > a2dp profiles, and in this reaserch its something to do with the latest > bluetooth drivers for vista home premium, so can anyone point me in the > correct direction for the drivers to enable a2dp please, or even a hack or > a > fix to this problem, thanks very much. |
| Guest | Re: Bluetooth headset help Hi there John, Thanks for the prompt reply, I have been into sound and the bluetooth speakers show up in there, and show a green bar moving up and down when I am playing music, but I cannot hear anything still. Doing more research its something to do with a2dp profiles or drivers. "John Lee Brown" wrote: Quote: > In support go to sounds then check to see that you have to speakers systems. > One is the normal speakers and the other is headphones, set the headphones > as the default. This should allow it to work. > "Garethm1976" <Garethm1976@xxxxxx> wrote in message > news:81EA2BA3-D3E5-4582-AEB9-8291DB057CC5@xxxxxx Quote: > > Hi there, > > I have just recieved a pair of i-tech blueband headphones > > > > http://www.itechdynamic.com/en/produ...id=3&pid=03030 > > > > i have been trying to connect these to my hp notebook dv2166eu > > > > http://h10025.www1.hp.com/ewfrf/wc/p...s=2093&lang=en > > > > The notebook connects to them fine and pairs with it ok, when I click web > > links I can hear the clicking noises the IE makes when you click on links, > > but when I try to listen to music/online radio or anything like that, I > > hear > > nothing. > > I have tried to do some reasearch and it seems its something to do > > with > > a2dp profiles, and in this reaserch its something to do with the latest > > bluetooth drivers for vista home premium, so can anyone point me in the > > correct direction for the drivers to enable a2dp please, or even a hack or > > a > > fix to this problem, thanks very much. > |
| bluetooth headset no sound | Sound & Audio | |||
| Bluetooth Headset | Vista General | |||
| Help: Bluetooth headset not working | Vista General | |||
| How do I get my bluetooth headset to work as a mic? | Vista hardware & devices | |||
| Bluetooth Headset in Vista | Vista General | |||
