| | Microsoft Wireless Desktop 7000 & Vista Business Bluetooth Problem Clean install of Vista Business on a new Dell Dimension desktop with 4GB of RAM and no other programs other than Office Small Business 2007, Windows Live OneCare, and IntelliPoint & IntelliType 6.1. All Microsoft Update patches are current. After the initial installation of the Desktop 7000 set (which went off without a hitch) both the mouse and the keyboard will stay connected and work well for a day or two and then just die, for no apparent reason, making me have to go through the "re-pairing" process again and again. By the way, I'm only utilizing the built-in Vista Microsoft Bluetooth stack; there were no Dell WIDCOMM drivers since the unit came with no native Bluetooth hardware. After that all is well for between 24 & 48 hours, then the process will repeat. Usually it manifests itself upon boot-up, but it also tends to happen when the computer wakes-up from sleep mode, which I don't allow it to go into very often. In trying to troubleshoot I moved the Microsoft Bluetooth transceiver (version 3.0) to the USB port in the side of the Dell flat panel monitor, thinking that its near proximity to the mouse and keyboard might improve things, but it didn't; the behavior was the same as before, when it was plugged into a USB 2.0 port in back of the computer. There's a garden-variety Linksys Wireless-G router about 3 feet away, but I don't think that could be causing any problems, at least none that have been reported so far. I'm loath to believe it has anything to do with the basic hardware, because when it works it works great; it just refuses to continue to do so from one (or two) day[s] to the next. To add to the mystery, I have this exact same Microsoft "Desk Set" on an older Dell Dimension with XP Professional, Office 2003 Small Business, Live OneCare, as well as a bunch of other programs and it hasn't missed a beat in over 6 months; not once has the mouse or keyboard lost connectivity or has had to be "re-paired" with the Microsoft dongle (transceiver), and that box gets twice as much use as this new one with Vista on it. What the Devil gives here? Any input or suggestions would be welcome. |
| | Re: Microsoft Wireless Desktop 7000 & Vista Business Bluetooth Problem Possible Causes -------------------- This issue can occur due to the following reasons. -Wireless Interference. -Depleted batteries. -Loss of Synchronization. -Use of Port Replicators, hubs, and third party adapters etc Suggestions ------------------- Perform these troubleshooting steps and this may help in resolving the issue. Step 1: Check for Interference: ------------------------------------------ Items such as Radio, Cell Phones, desktop fans, Fluorescent lights, Large metal objects, including computer cases and metal furniture may interfere with the signal of the mouse. Please keep the items away from the mouse and check the behavior of the mouse. I also suggest you to check out the following Microsoft Online Knowledge Base Article: Wireless Keyboard or Mouse May Not Respond or May Respond Intermittently http://support.microsoft.com/kb/821805 If you have connected the receiver using a green USB to PS/2 converter, then please try removing the adapter and connect the USB connector directly. Step 2: Use fresh Energizer batteries: ----------------------------------------------------- Let us ensure to remove the existing set of batteries from the mouse compartment and insert a new set of AA Alkaline batteries. Now see how the mouse works. In case the issue persists, proceed to the next step. Step 3: Try on different ports: ----------------------------------------- Let us try the connection scenarios as mentioned in method 1 of the following Microsoft Knowledge Base Article: Wireless keyboard or mouse does not respond as expected: http://support.microsoft.com/kb/838398 After trying each connection scenario, try the steps in Method 3 of the same article to synchronize the keyboard with the receiver. If the above suggestions do not help: Contact Microsoft hardware support and request a hardware replacement at no charge: https://support.microsoft.com/oas/default.aspx?tp=il ------------------------------------------------------------------------------------------- "Travis" wrote: Clean install of Vista Business on a new Dell Dimension desktop with 4GB of RAM and no other programs other than Office Small Business 2007, Windows Live OneCare, and IntelliPoint & IntelliType 6.1. All Microsoft Update patches are current. After the initial installation of the Desktop 7000 set (which went off without a hitch) both the mouse and the keyboard will stay connected and work well for a day or two and then just die, for no apparent reason, making me have to go through the "re-pairing" process again and again. By the way, I'm only utilizing the built-in Vista Microsoft Bluetooth stack; there were no Dell WIDCOMM drivers since the unit came with no native Bluetooth hardware. After that all is well for between 24 & 48 hours, then the process will repeat. Usually it manifests itself upon boot-up, but it also tends to happen when the computer wakes-up from sleep mode, which I don't allow it to go into very often. In trying to troubleshoot I moved the Microsoft Bluetooth transceiver (version 3.0) to the USB port in the side of the Dell flat panel monitor, thinking that its near proximity to the mouse and keyboard might improve things, but it didn't; the behavior was the same as before, when it was plugged into a USB 2.0 port in back of the computer. There's a garden-variety Linksys Wireless-G router about 3 feet away, but I don't think that could be causing any problems, at least none that have been reported so far. I'm loath to believe it has anything to do with the basic hardware, because when it works it works great; it just refuses to continue to do so from one (or two) day[s] to the next. To add to the mystery, I have this exact same Microsoft "Desk Set" on an older Dell Dimension with XP Professional, Office 2003 Small Business, Live OneCare, as well as a bunch of other programs and it hasn't missed a beat in over 6 months; not once has the mouse or keyboard lost connectivity or has had to be "re-paired" with the Microsoft dongle (transceiver), and that box gets twice as much use as this new one with Vista on it. What the Devil gives here? Any input or suggestions would be welcome. |
| | Re: Microsoft Wireless Desktop 7000 & Vista Business Bluetooth Pro I have exactly the same problem on Vista Ulltimate and XP pro. I have tried removing the Intellpoint software, but when you reinstall and asked to remove Bluetooth transciever,refit and hold button for 5 sec. plus, it just hangs and does nothing, I have left it for 2 hours and nothing. The only way is to add Bluetooth device and as you say it last, with me about 2 weeks. It's a pity they didn't give any warnings about the interferance problems before taking the £80.00. I am having to use a wired keyboard and mouse, incase I need to boot into Bios or boot menu. Thats 2 mice & 2 keyboards defeats the object in my view glad I didn't buy the Desktop 8000. Can any one sugest a desktop set that works "Carey Frisch MVP]" wrote: Quote: > Possible Causes > -------------------- > This issue can occur due to the following reasons. > > -Wireless Interference. > -Depleted batteries. > -Loss of Synchronization. > -Use of Port Replicators, hubs, and third party adapters etc > > > Suggestions > ------------------- > Perform these troubleshooting steps and this may help in resolving the issue. > > > Step 1: Check for Interference: > ------------------------------------------ > Items such as Radio, Cell Phones, desktop fans, Fluorescent lights, Large metal objects, > including computer cases and metal furniture may interfere with the signal of the mouse. > Please keep the items away from the mouse and check the behavior of the mouse. > > > I also suggest you to check out the following Microsoft Online Knowledge Base Article: > > > Wireless Keyboard or Mouse May Not Respond or May Respond Intermittently > http://support.microsoft.com/kb/821805 > > > If you have connected the receiver using a green USB to PS/2 converter, then please > try removing the adapter and connect the USB connector directly. > > > Step 2: Use fresh Energizer batteries: > ----------------------------------------------------- > Let us ensure to remove the existing set of batteries from the mouse compartment > and insert a new set of AA Alkaline batteries. Now see how the mouse works. > > > In case the issue persists, proceed to the next step. > > > Step 3: Try on different ports: > ----------------------------------------- > Let us try the connection scenarios as mentioned in method 1 of the following > Microsoft Knowledge Base Article: > > > Wireless keyboard or mouse does not respond as expected: > http://support.microsoft.com/kb/838398 > > > After trying each connection scenario, try the steps in Method 3 of the same article > to synchronize the keyboard with the receiver. > > > If the above suggestions do not help: > > > Contact Microsoft hardware support and request a hardware replacement > at no charge: https://support.microsoft.com/oas/default.aspx?tp=il > > ------------------------------------------------------------------------------------------- > > > "Travis" wrote: > > Clean install of Vista Business on a new Dell Dimension desktop with 4GB of > RAM and no other programs other than Office Small Business 2007, Windows Live > OneCare, and IntelliPoint & IntelliType 6.1. > > All Microsoft Update patches are current. > > After the initial installation of the Desktop 7000 set (which went off > without a hitch) both the mouse and the keyboard will stay connected and work > well for a day or two and then just die, for no apparent reason, making me > have to go through the "re-pairing" process again and again. By the way, I'm > only utilizing the built-in Vista Microsoft Bluetooth stack; there were no > Dell WIDCOMM drivers since the unit came with no native Bluetooth hardware. > > After that all is well for between 24 & 48 hours, then the process will > repeat. > > Usually it manifests itself upon boot-up, but it also tends to happen when > the computer wakes-up from sleep mode, which I don't allow it to go into very > often. > > In trying to troubleshoot I moved the Microsoft Bluetooth transceiver > (version 3.0) to the USB port in the side of the Dell flat panel monitor, > thinking that its near proximity to the mouse and keyboard might improve > things, but it didn't; the behavior was the same as before, when it was > plugged into a USB 2.0 port in back of the computer. > > There's a garden-variety Linksys Wireless-G router about 3 feet away, but I > don't think that could be causing any problems, at least none that have been > reported so far. > > I'm loath to believe it has anything to do with the basic hardware, because > when it works it works great; it just refuses to continue to do so from one > (or two) day[s] to the next. > > To add to the mystery, I have this exact same Microsoft "Desk Set" on an > older Dell Dimension with XP Professional, Office 2003 Small Business, Live > OneCare, as well as a bunch of other programs and it hasn't missed a beat in > over 6 months; not once has the mouse or keyboard lost connectivity or has > had to be "re-paired" with the Microsoft dongle (transceiver), and that box > gets twice as much use as this new one with Vista on it. > > What the Devil gives here? > > Any input or suggestions would be welcome. |
| Problem Microsoft Wireless Laser Mouse 8000 - Bluetooth | Vista hardware & devices | |||
| Microsoft wireless 7000 keyboard | .NET General | |||
| Microsoft wireless 7000 Bluetooth | Vista hardware & devices | |||
| Microsoft Wireless Entertainment 7000 | Vista hardware & devices | |||
| Microsoft wireless keyboard 7000 | Vista hardware & devices | |||
