Vista - usb hub does not wake after sleep
Old 09-07-2007   #1 (permalink)
Michael Tissington
I have a powered USB hub connected into a USB slot.
When the computer goes to sleep, the hub goes to sleep too.
The problem is when the computer wakes up the USB hub remains asleep.
Any ideas please ?
Old 09-08-2007   #2 (permalink)
Juarez
Re: usb hub does not wake after sleep
> Any ideas please ?
Is it a powered hub? POwered hubs are better and if it isn't
powered it may not be getting enough power to wake it up. Probably the only
solution is to go to device manager and set the properties for the hub's
port not to be allowed to put to sleep in the first place.
Can't Wake PC From Sleep General Discussion
S3 STR Sleep Can NOT Wake up Drivers
sleep and won't wake up Vista General
Can't wake after sleep/Hib. Vista installation & setup
Wake from sleep Vista General
