| | Problems with generic USB hardware While trialing Windows Vista these days, i bumped to an unusual problem. After few days of working fine, it started to appear that every time i plug in an USB device (flash or another ordinary mass storage device) the wizard 'found new hardware' pops up and i have to manually point to C:\Windows directory to be able to install the driver for an ordinary USB flash stick (sometimes i even see two or three popups for one device, and everything has to be installed manually). I never had such problem with my Win XP before, installations of generic devices were always automatic. Also searched other forums and google, and it seems that many people are experiencing similar problems (might be due to some pice of software installed, but nobody san pinpoint which one). So....does anyone knows a solution to these problems? Also, I belive it would be smart that Microsoft's technical stuff is notified since this might be a possible bug in OS (as i said, many people are experiencing it), so that they can come up with a viable solution, possibly in a form of an update or something similar. Thanks! Ivan ---------------- This post is a suggestion for Microsoft, and Microsoft responds to the suggestions with the most votes. To vote for this suggestion, click the "I Agree" button in the message pane. If you do not see the button, follow this link to open the suggestion in the Microsoft Web-based Newsreader and then click "I Agree" in the message pane. http://windowshelp.microsoft.com/com...rdware_devices |
| | Re: Problems with generic USB hardware This solution has worked for some people with problematic USB devices: Locate the file INFCACHE.1 in C:\Windows\inf Right click on the INFCACHE.1 file, select Properties >Security > Edit, and give your account full control. Delete INFCACHE.1, or rename it to INFCACHE.1.BAK or temporarily move to your desktop. REBOOT I Bleed Blue and Gold GO BEARS! "Toxical" <Toxical@xxxxxx> wrote in message news:2E400AF1-D7AF-4C78-8E6C-FA98AFCCDED9@xxxxxx Quote: > While trialing Windows Vista these days, i bumped to an unusual problem. > After few days of working fine, it started to appear that every time i plug > in an USB device (flash or another ordinary mass storage device) the wizard > 'found new hardware' pops up and i have to manually point to C:\Windows > directory to be able to install the driver for an ordinary USB flash stick > (sometimes i even see two or three popups for one device, and everything has > to be installed manually). I never had such problem with my Win XP before, > installations of generic devices were always automatic. Also searched other > forums and google, and it seems that many people are experiencing similar > problems (might be due to some pice of software installed, but nobody san > pinpoint which one). > So....does anyone knows a solution to these problems? > Also, I belive it would be smart that Microsoft's technical stuff is > notified since this might be a possible bug in OS (as i said, many people are > experiencing it), so that they can come up with a viable solution, possibly > in a form of an update or something similar. > Thanks! > Ivan > > ---------------- > This post is a suggestion for Microsoft, and Microsoft responds to the > suggestions with the most votes. To vote for this suggestion, click the "I > Agree" button in the message pane. If you do not see the button, follow this > link to open the suggestion in the Microsoft Web-based Newsreader and then > click "I Agree" in the message pane. > > http://windowshelp.microsoft.com/com...rdware_devices |
| | Re: Problems with generic USB hardware Hot Damn! it worked! ![]() Thanks a MILLION! I'll try to post this on other forums where users also have this problem but don't know how to fix it. Cheers! |
| | Re: Problems with generic USB hardware You're welcome. You can now delete (if you haven't already) the INFCACHE.1 file (Windows will not recreate it). -- I Bleed Blue and Gold GO BEARS! "Toxical" <Toxical@xxxxxx> wrote in message news:73D90390-6772-4F48-917A-7DEBEECB1BF7@xxxxxx Quote: > Hot Damn! it worked! ![]() > Thanks a MILLION! > I'll try to post this on other forums where users also have this problem but > don't know how to fix it. > Cheers! |
| Vista Generic Hardware Driver Issue | Vista hardware & devices | |||
| poss solution to generic volume and usb drive problems | Vista hardware & devices | |||
| setting up new hardware problems | Vista installation & setup | |||
| Hardware problems... | Vista hardware & devices | |||
| Hardware problems | Vista installation & setup | |||
