| | No Audio Output Device Installed "Please Help!!!" i recently updated windows to find that i get this error msg about me not having an audio output device, i thought if i did i system restore that i might have been able to resolve the problem, but that was a no go. I checked the device manager if it was my sound card, but it tells me that the card is working properly. Now I'm at a dead end and have absolutely no idea why it is like this. I'd like to note that i am using a Gateway MT3422 Notebook with on board speakers and a SigmaTel High Definition Audio CODEC, which i tried updating but had no luck with. Any help at all would be extremely appreciated, thank you. |
| | Re: No Audio Output Device Installed "Please Help!!!" i recently updated windows to find that i get this error msg about me not having an audio output device, i thought if i did i system restore that i might have been able to resolve the problem, but that was a no go. I checked the device manager if it was my sound card, but it tells me that the card is working properly. Now I'm at a dead end and have absolutely no idea why it is like this. I'd like to note that i am using a Gateway MT3422 Notebook with on board speakers and a SigmaTel High Definition Audio CODEC, which i tried updating but had no luck with. Any help at all would be extremely appreciated, thank you. -- Harouna Posted via http://www.vistaheads.com |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: No Audio Output Device Installed "Please Help!!!" i recently updated windows to find that i get this error msg about me not having an audio output device, i thought if i did i system restore that i might have been able to resolve the problem, but that was a no go. I checked the device manager if it was my sound card, but it tells me that the card is working properly. Now I'm at a dead end and have absolutely no idea why it is like this. I'd like to note that i am using a Gateway MT3422 Notebook with on board speakers and a SigmaTel High Definition Audio CODEC, which i tried updating but had no luck with. Any help at all would be extremely appreciated, thank you. -- Harouna Posted via Microsoft Windows Vista Community Forums - Vistaheads Sometimes Audio drivers need to be installed twice. Once to remove the old driver, and twice to install the new one. Other times, a simple restart is required to finish the installation. Hope this helps, Shawn |
| Help Needed: "No audio output device is installed" | Sound & Audio | |||
| Dell and "no audio output device installed" after Vista upgrade | Vista hardware & devices | |||
| "No Audio Output Device is installed" | Vista hardware & devices | |||
| "No Audio Output Device is installed"? | Vista hardware & devices | |||
| "No audio output device is installed" upon wake-up... | Vista hardware & devices | |||
