Vista - Dvd Driver does not read
Old 09-09-2007   #1 (permalink)
pierro_a
My dvd driver not respond to any of disc i place when i open dvd drive thru
my computer the no disc responce i keep eject and closing the tray but
nothing please help me
Old 09-09-2007   #2 (permalink)
Cal Bear '66
Re: Dvd Driver does not read
Try this:
http://support.microsoft.com/default...b/929461/en-us
I Bleed Blue and Gold
GO BEARS!
"pierro_a" <pierroa@xxxxxx> wrote in message
news:EB960F3C-8897-4B78-88C7-7AB29B74298D@xxxxxx
Old 09-09-2007   #3 (permalink)
Win XP Pro / Win Vista Ultimate
- try a system restore.
- if the problem continues, uninstall it from the device manager and restart the computer.
- make sure no DVD is in the drive when you turn on the computer.
Old 09-09-2007   #4 (permalink)
pierro_a
it not vista it xp just cant find the dam forum for xp section
and still dont know
"Cal Bear '66" wrote:
Quote:
> Try this:
> GO BEARS!
Old 09-09-2007   #5 (permalink)
abdelkader.allilat
abdelkader.allilat@xxxxxx
"pierro_a" wrote:
> and still dont know
Quote:
> > Try this:
> > GO BEARS!
Old 09-09-2007   #6 (permalink)
Cal Bear '66
For XP try this:
http://support.microsoft.com/default...b/314060/en-us
GO BEARS!
news:5ECE6AA3-1121-49B7-AE27-274A588E9E4C@xxxxxx
> and still dont know
Quote:
>> Try this:
>> GO BEARS!
Old 02-03-2008   #7 (permalink)
Arthrodire
Cal Bear 66 saved my ass! The method he suggested - as outlined in the link
- worked for me. I have a new Acer computer running Vista Home Premium. I
had no problem with the disc drive since I bought it (2 weeks ago) until now.
Today - all of a sudden! -I insert a DVD and nothing happened. I inserted
a different one and still nothing happened. Then I looked under START /
COMPUTER and it didn't even show up as having a disc drive. I freaked! I
called the store and they gave me no suggestions (typical) but I found this
discussion group and went through a lot of talk until I came upon Cal Bear 66
suggestion. I did as instructed in the link - VERY CAREFULLY - and presto!
THANK YOU VERY MUCH Cal Bear 66!
ps - In the final steps it says remove the Upper Filter and also the Lower
Filter. I did not see a Lower Filter in my list but I did find an Upper
Filter which I removed and it solved the problem.
Quote:
> Try this:
> GO BEARS!
Computer fails to read D driver Drivers
driver id details - where to read about? Vista performance & maintenance
Do You Need A Different Driver For Different Computers To Print? Read This. Vista General
Trouble With Hardware Driver, No Need 2 Post, Read This Vista hardware & devices
Do You Need A Different Driver For Different Computers To Print? Read This. Vista print fax & scan
