Vista - Have Problem With Hardware Devices? Try This Before Posting
Old 09-09-2007   #1 (permalink)
jonathan perreault
Try this fix to see if it repairs your problem. This solution has worked for
some people with problematic USB and General Devices:
1. Locate the file INFCACHE.1 in C:\Windows\inf
2. Right click on the INFCACHE.1 file, select Properties >Security > Edit,
and give your account full control.
3. Delete INFCACHE.1 (Or just to be safe, rename it to INFCACHE.1.BAK or
temporarily move to your desktop but you shouldn't need to, windows doesn't
need that file to run, and if it needs to it recreates it).
4. REBOOT
Jonathan Perreault
Old Advise: Do Not Undermine Windows's Work,
Or It'll Undermine You As A User.
New Word Of Advice: Torture Windows (Any) Now
Before It Tortures You
Old 09-10-2007   #2 (permalink)
lamawithonel
RE: Have Problem With Hardware Devices? Try This Before Posting
MS,
What's the official stance on this problem? My searches suggest it's
existed since at least beta. Why no fix?
> 4. REBOOT
> Jonathan Perreault
Old 09-10-2007   #3 (permalink)
jonathan perreault
Re: Have Problem With Hardware Devices? Try This Before Posting
i wouldn't know really, i don't keep up with what microsoft is doing, i'm
just someone who had some problems with that file, and i used that temporary
fix and everything worked well afterwards. but i can't wait untill they get
that fix, my guess is they are still experimenting with the fix to make sure
the bugs are minimal.
Jonathan Perreault
Old Advice #1: Do Not Undermine Windows's Work, New Advice#2: Torture
Windows (Any) Now
Comment: No Matter The Problem Even With Linux
It's Microsoft's And Windows's Faults
"lamawithonel" <lamawithonel@xxxxxx> wrote in message
news:8C4009A0-3CED-4B94-BF49-B146891794A8@xxxxxx
Quote:
> MS,
>> for
>> Edit,
>> doesn't
>> 4. REBOOT
>> Jonathan Perreault
Hardware failing-one or more devices??? General Discussion
Hardware devices problem in vista home Vista hardware & devices
HARDWARE & DEVICES Vista hardware & devices
wireless hardware devices Vista hardware & devices
