Vista - Trouble With Hardware Driver, No Need 2 Post, Read This
Old 09-11-2007   #1 (permalink)
jonathan perreault
Try this fix to see if it repairs your problem, Before Posting. This
solution has worked for
some people with problematic USB and General Devices:
1. Locate the file INFCACHE.1 in C:\Windows\inf
2. Right click on the INFCACHE.1 file, select Properties >Security > Edit,
and give your account full control.
3. Delete INFCACHE.1 (Or just to be safe, rename it to INFCACHE.1.BAK or
temporarily move to your desktop but you shouldn't need to, windows doesn't
need that file to run, and if it needs to it recreates it).
4. REBOOT
Jonathan Perreault
Personnal Advice To You:
#1: Do Not Undermine Windows's Work, Or It'll Undermine You As A User.
#2: Torture Windows (Any) Now Before It Tortures You
Best Comments From Users:
No Matter The Problem Even With Linux, It's Microsoft's And Windows's Faults
A common mistake that people make when trying to design something completely
foolproof is to underestimate the ingenuity of complete fools.
irql_not_less_or_equal Pre & Post Hardware Fix General Discussion
Ram & CPU trouble in POST Overclocking & Cooling
Windows cannot load the device driver for this hardware. The driver may be corrupted Drivers
Trouble With Any Device? Don't Post Read This First Vista hardware & devices
How sensitive is Vista to Hardware changes ? Read On. Vista General
