1.    13 Sep 2007 #1
    Drokare Guest
    Laptop with attached Monitor does not work properly
    I have a Dell 9300 with an attached Acer AL2251W 22" Wide Screen Monitor,
    with Vista Ultimate.
    When I first installed it I could see the complete window, then over a week
    ago I lost about 2 inches from the right side of the monitor.
    I then downloaded the Vista Drivers for the Monitor that I downloaded from
    the Acer Website. This did not resolve the issue.
    Now what is wierd, is I created another profile on my machine, this new user
    was to troubleshoot another issue I am having. Well when I first logged into
    the new user, the Monitor displayed correctly, no unusable black bar on the
    right side. But when it asked me how to handle the monitor (display the same
    desktop or extend) I chose extend and I gained the missing space again. I
    tried creating another user and this time selected keep the same view and
    same thing. I created another user and tried canceling the selection and
    again I gained the black bar.
    Now if I lower the resolution it works fine, but it is setup and is optimal
    for 1680 x 1050.
    Any Ideas? I can not find anything on the web about this, and it is strange
    that when I first login into a new user it works correctly until the display
    properties come up???
    Thanks for you time.
  2.    15 Sep 2007 #2
    sebbelcher Guest
    RE: Laptop with attached Monitor does not work properly
    It sounds to me that when you are selecting 'Extend' or 'Clone' Windows is
    applying the same desktop resolution to both monitors, hence the incorrect
    size on the external screen. As I do not have two monitors connected at the
    moment, this is coming from memory, and will also depend on your graphics
    driver software, but here goes...
    Windows does allow independent configuration of resolutions on monitors,
    though sometimes it can be hard to work out which screen you are changing.
    As your laptop screen looks ok, I will assume the incorrect resolution is
    being applied to the external screen. On the display options (right click
    desktop->Personalize->Display Settings) you will have a panel that will show
    graphical representations of the two monitors, your laptop screen will most
    likely be number 1 and the monitor number 2. Though it is not obvious, the
    options below (resolution etc) apply the the screen that is currently
    selected above, so first click on the number 2 screen, then select the
    correct native resolution from the options below, click apply and this
    *should* solve your problem.
    If not then I would guess the third-party control panel provided my your
    graphics card manufacturer is overriding these settings, you'll have to give
    me more info if this is the case.
    Seb.
    > for 1680 x 1050.
  3.    17 Sep 2007 #3
    Drokare Guest
    Seb... Thank you for replying.
    I have checked the Dispaly settings and it both "monitors" are set
    correctly. As I said earlier, if I lower the resolution on the 22" from the
    factory suggested then it works fine, so if I lower it to 1440x900 it looks
    works, but the monitor is made for 1680x1050 and anything lower just does not
    look as good.
    I am running the latest drivers from the Manufacturer for my Video Card, and
    when I had my 19" Wide Screen it worked great, and I have seen the it display
    correctly at 1680x1050 before. And it displays correctly when I create a new
    user/profile until Windows Mobility Center pops up to ask we how to handle
    the other monitor. I feel it WMC that is somehow causing the issue, is there
    a way to turn WMC off?
    -Drokare
    > Seb.
    > > for 1680 x 1050.
  4.    18 Sep 2007 #4
    Spirit Guest
    Re: Laptop with attached Monitor does not work properly
    Make sure you have ALL the utilities for the monitor installed. Also
    some monitors only work at certain resolutions when the Frequency is
    set to specific a certain range. Does the monitor work at all resolutions
    when hooked up as Analog and/or DVI?
    "Drokare" <Drokare@xxxxxx> wrote in message
    news:637313C4-AE0D-46F7-877B-30FF48367479@xxxxxx
    > the
    > looks
    > not
    > look as good.
    > and
    > display
    > new
    > there
    > -Drokare
    >> is
    >> incorrect
    >> the
    >> changing.
    >> click
    >> show
    >> most
    >> the
    >> give
    >> Seb.
    >> > Monitor,
    >> > week
    >> > from
    >> > user
    >> > logged into
    >> > the
    >> > the same
    >> > I
    >> > and
    >> > and
    >> > optimal
    >> > for 1680 x 1050.
    >> > strange
    >> > display
10 BSOD in a week with new laptop. Y? (debug log attached)
First post (hi). I'll buy a coffee to anyone who can fix this problem... New laptop, Sager NP 9280 i7 950, 6g ram, 280m GPU, Vista Home Premium...
General Discussion
My Xp laptop cannot print using printer attached to my vista machi
I have a new windows vista desktop (windows home premium 32 bit). I have it set up to share file/folders with my laptop which is running XP home. ...
Vista print fax & scan
full laptop keyboard doesn't work properly under vista
Hi everyone, So I've got my new Fujitsu-Siemens Amilo Xi 1526 notebook with 17" screen and thus a full keyboard with separate numeric keypad. The...
Vista hardware & devices
Monitor not resizing properly
ok specs first, Im running Vista home prem. 2 Nvidia 7800 GT's in sli. and I have 4 gig of memory. When ever I run a game on my computer that...
Laptop with ME can't find printer attached to Vista
I have a two computer home wireless network using TrendNet TEW-432BRP wireless router attached to a new HP Compaq computer running Vista Home...
Vista networking & sharing
USB attached devices do not work with windows Vista
The problem is the USB controller installed on Microsoft Vista (all versions) does not function with the BIOS of several motherboards. Microsoft...
Vista General
How to put Linux on your laptop. JPG file attached.
For the Linux fans amongst us.
Vista General
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • PC Help Forum
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
