| | Gamma *PLEASE HELP* Anyone know of a good small utility to adjust GAMMA in Vista Ultimate? I tried Gamma Panel and Quickgamma, they're old and buggy in Vista, works better in XP. Both do not automatically start up with the saved settings, AND turn off by itself after you manually restart them. Intel's video driver only allows you to adjust contrast and brightness as stupid as it sounds. I have Intel 945GM chipset on my Sony laptop and latest drivers as of today .. This is mainly pathetic by far on Intel's side. The brainless reasoning behind NOT allowing you to adjust gamma below 1.0 on their software/driver I'll never figure out. |
| | Re: Gamma *PLEASE HELP* What part of this did you not comprehend? "The brainless reasoning behind NOT allowing you to adjust gamma below 1.0 on their software/driver I'll never figure out." See, it does not allow you to adjust gamma BELOW 1.0!! |
| Need global gamma level | General Discussion | |||
| ADOBE GAMMA | Vista installation & setup | |||
| Gamma | Vista General | |||
| Gamma *PLEASE HELP* | Vista General | |||
| gamma on laptop | Vista performance & maintenance | |||
