Vista Tutorial - Keyboard repeat rate/repeat delay speed automatically resets
Old 09-19-2007   #1 (permalink)
Turkk
Guest
Our office has recently installed two HP computers (slightly different) both
running Vista Business. With both PCs we have the same problem: when the
machine is put into sleep mode, or shut down, the key repeat rate and repeat
delay speeds reset & slow down. This means that every morning we have to go
into Control Panel & reset both at the highest levels--otherwise the curser
moves slowly & we can't type fast. For some reason Vista just isn't setting
these as 'permanent' settings.
I have spent a great deal of time on the phone with HP and they say it
has to be a software problem in Vista. Any ideas? Many thanks!
Turkk
Old 09-19-2007   #2 (permalink)
Cal Bear '66
Guest
Re: Keyboard repeat rate/repeat delay speed automatically resets
Be sure to press the "Apply" button after making changes before pressing the
"OK" button.
Are there any new Vista keyboard drivers available from HP?
I Bleed Blue and Gold
GO BEARS!
"Turkk" <Turkk@xxxxxx> wrote in message
news:BCEC1730-7135-49DC-A7E0-788542A7E04B@xxxxxx
> Turkk
Old 09-20-2007   #3 (permalink)
Uwe Sieber
Guest
I have the same problem under XP on two computers with
a KVM switch. The repeat rate switches to 'slow' again
and again for no reason.
I've made a simple program that set the parameters
back to minimum delay and maximum repeat rate. So I can
switch back with a single click.
http://www.uwe-sieber.de/files/fastkeys.zip
Uwe
Old 09-20-2007   #4 (permalink)
Turkk
Guest
Yes, I clicked apply; and no, there aren't any updates.
Turkk
"Cal Bear '66" wrote:
> "OK" button.
> GO BEARS!
> > Turkk
Vista keyboard (repeat delay, repeat rate) Vista General
Keyboard properties (repeat delay, repeat rate) Vista General
Keyboard Repeat Delay Vista hardware & devices
Keyboard 'Repeat Delay' and 'Repeat Rate' Vista General
Keyboard repeat rate too fast Vista General
