Vista - Reinstalling TV Tuner Card After Every Restart
Old 09-20-2007   #1 (permalink)
Dylan Harrelson
Setup:
Windows Vista Ultimate 64-Bit
Asus Crosshair
(2) XFX 8800GS
Hauppage HVR-1600
I've recently been having complications with my tuner card with MCE (green
screen, choppy video) I finally solved the issue by installing the latest
versions of DirectX 10 & Nvidia Drivers (Sept. 18).
Well after doing that the tuner work immediately after installing the new
drivers, however once I rebooted my computer I had issues with green screen
and choppy video. Each time this happens I have to uninstall the tuner card,
reboot, then reinstall the driver for it.
Is there anything I can do to avoid the operating system from causing this
problem?
TV Tuner card Vista hardware & devices
Compatible Tuner Card Vista General
Re: tv tuner card Vista General
tv tuner card Vista hardware & devices
