| | PCI parallel card can not work Recently I bought a PCI 1-parallel-2-serial card. After I pluged the card and installed the driver, the software using parallel port doesn't work. On Device property/General page, it says "work well", but on Device property/Resources page, it says "I/O range ... not available". I can not change the setting because the checkbox of "Use automatic setting" is grayed. (Btw, I posted the information following a post thread named "LPT3 should be LPT1" and even I received a inform says someone replied. But the link lead me to a "Discuss group not found". I don't know what happened. Is there someone deleted it? The link I received is http://windowshelp.microsoft.com/com...7-0b01a12a0e6a ) |
| | RE: PCI parallel card can not work Hi John, Did you followed the instructions correctly? Sometimes you need to install the software BEFORE the card and sometimes AFTER. You could also try a different slot to see if that helps. You might need to change a setting in your BIOS, usually Clear Configuration Data or similar, see your motherboard manual for details. Another thing - are you sure that the driver is Vista compatible? If not, you might be able to download a compatible driver from the manufacturers website. Dwarf "John Xia" wrote: Quote: > Recently I bought a PCI 1-parallel-2-serial card. After I pluged the card and > installed the driver, the software using parallel port doesn't work. On > Device property/General page, it says "work well", but on Device > property/Resources page, it says "I/O range ... not available". I can not > change the setting because the checkbox of "Use automatic setting" is grayed. > (Btw, I posted the information following a post thread named "LPT3 should be > LPT1" and even I received a inform says someone replied. But the link lead me > to a "Discuss group not found". I don't know what happened. Is there someone > deleted it? > The link I received is > http://windowshelp.microsoft.com/com...7-0b01a12a0e6a > ) > |
| | RE: PCI parallel card can not work Hi Dwarf, Thank you for your answer. Afterward I realized maybe I should ignore the "...not available" message, because the card device has all resources which also belong to ports, without conflict. I guess the problem is the application software fixed the LPT port base address. I'm trying to figure out how to change that setting. "Dwarf" wrote: Quote: > Hi John, > > Did you followed the instructions correctly? Sometimes you need to install > the software BEFORE the card and sometimes AFTER. You could also try a > different slot to see if that helps. You might need to change a setting in > your BIOS, usually Clear Configuration Data or similar, see your motherboard > manual for details. Another thing - are you sure that the driver is Vista > compatible? If not, you might be able to download a compatible driver from > the manufacturers website. > Dwarf > > "John Xia" wrote: > Quote: > > Recently I bought a PCI 1-parallel-2-serial card. After I pluged the card and > > installed the driver, the software using parallel port doesn't work. On > > Device property/General page, it says "work well", but on Device > > property/Resources page, it says "I/O range ... not available". I can not > > change the setting because the checkbox of "Use automatic setting" is grayed. > > (Btw, I posted the information following a post thread named "LPT3 should be > > LPT1" and even I received a inform says someone replied. But the link lead me > > to a "Discuss group not found". I don't know what happened. Is there someone > > deleted it? > > The link I received is > > http://windowshelp.microsoft.com/com...7-0b01a12a0e6a > > ) > > |
| Can not get graphics card to work- help | Graphic cards | |||
| Sound Card to work on Lap Top | Sound & Audio | |||
| PCI Express Parallel Card Installation Problem | Vista hardware & devices | |||
| 2 network card don't work help | Vista networking & sharing | |||
| Parallel Card for printer | Vista General | |||
