Vista - UBB Hard drive and Flash Drive
Old 09-23-2007   #1 (permalink)
ds223
I have Vista Ultimate, when I connect a usb hard drive or flash drive to the
pc windows cant find the drivers for them.
But if I connect the same drives to a Vista Home Premium PC, that pc can
install the drivers for them.
Any ideas what is happening here?
Thanks
Old 09-23-2007   #2 (permalink)
Cal Bear '66
Re: UBB Hard drive and Flash Drive
This solution has worked for some people with problematic USB devices:
Locate the file INFCACHE.1 in C:\Windows\inf
Right click on the INFCACHE.1 file, select Properties >Security > Edit, and give
your account full control.
Delete INFCACHE.1, or rename it to INFCACHE.1.BAK or temporarily move to your
desktop.
REBOOT
I Bleed Blue and Gold
GO BEARS!
"ds223" <ds223@xxxxxx> wrote in message
news:3B10FE3B-D024-43B7-9F8C-27CD39135A54@xxxxxx
> Thanks
Hard drive light constantly flashing ,reading hard drive during id Vista hardware & devices
USB hard drive and flash drives not recognized in Vista 32 Vista hardware & devices
External Hard Drive vs Flash Drive Virtual PC
Crashed hard drive...copied hard drive but can't access User area Vista General
Transferring files from Slave XP hard drive to new Vista Hard drive - primary Vista installation & setup
