| | Resume from standby problem Hi, I have a Samsung 22" SyncMaster 225BW LCD monitor and an EVGA 7900 ko gt video card. I have a fresh copy of Vista 64 bit home premium installed with the latest updates. When my computer resumes from standby, the monitor refresh rate goes nuts. I can't make out anything on the screen and upon resetting the box, Vista boots up with the screwed up refresh rate. I'm trying to find a "vga" mode to boot into, but the troubleshooting boot menu does not offer it as an option. The only way I've been able to fix this is to roll back my system using system restore, then changing my resolution to 1024 x 768 and then allowing windows update to re-install it's previous update. Using safe mode and setting my resolution to a lower quality does not seem to help. On re-boot, the system resumes it's screwy refresh rate. I've also experimented with the latest Nvidia drivers with the same result on resume from standby. Any suggestions? Can anyone tell me how to get the system to use vga mode on boot? |
| | Re: Resume from standby problem Since your monitor is a 16:10 aspect ratio monitor with a native resolution of 1680x1050 why are you trying to send it 4:3 aspect ratio 1024x768? You should have the best results with drivers from the NVIDIA Website since they are normally more up to date then the ones from WinUpdate. "Leroy" <leroy.lemon@xxxxxx> wrote in message news:OdBgOOEAIHA.1184@xxxxxx Quote: > Hi, > > I have a Samsung 22" SyncMaster 225BW LCD monitor and an EVGA 7900 ko gt > video card. > I have a fresh copy of Vista 64 bit home premium installed with the latest > updates. > When my computer resumes from standby, the monitor refresh rate goes nuts. > I can't make out anything on the screen and upon resetting the box, Vista > boots up with the screwed up refresh rate. > I'm trying to find a "vga" mode to boot into, but the troubleshooting boot > menu does not offer it as an option. > > The only way I've been able to fix this is to roll back my system using > system restore, then changing my resolution to 1024 x 768 and then > allowing windows update to re-install it's previous update. > > Using safe mode and setting my resolution to a lower quality does not seem > to help. On re-boot, the system resumes it's screwy refresh rate. > > I've also experimented with the latest Nvidia drivers with the same result > on resume from standby. > > Any suggestions? > Can anyone tell me how to get the system to use vga mode on boot? > > |
| | Re: Resume from standby problem Perhaps I should clarify my situation..... My monitor defaults to 1680 x 1050 resolution, sweet... I have no problem with that and I should've stated that first. When my system goes for a nap it wakes up very cranky with a whacked out refresh rate. I cannot see anything and I have to reset the system and go into safe mode. The only way to fix the problem is to do a system restore to an earlier time, set my resolution to 1024 x 768, allow any auto updates to occur and THEN set my resolution back to 1680 x 1050. And of course then I'm back to square one. Go for nap, wake up cranky.... btw, do you have any answers to my questions? "JW" <JW@xxxxxx> wrote in message news:88617FF3-354B-471F-827D-DF9651D4635F@xxxxxx Quote: > Since your monitor is a 16:10 aspect ratio monitor with a native > resolution of 1680x1050 why are you trying to send it 4:3 aspect ratio > 1024x768? > You should have the best results with drivers from the NVIDIA Website > since they are normally more up to date then the ones from WinUpdate. > "Leroy" <leroy.lemon@xxxxxx> wrote in message > news:OdBgOOEAIHA.1184@xxxxxx Quote: >> Hi, >> >> I have a Samsung 22" SyncMaster 225BW LCD monitor and an EVGA 7900 ko gt >> video card. >> I have a fresh copy of Vista 64 bit home premium installed with the >> latest updates. >> When my computer resumes from standby, the monitor refresh rate goes >> nuts. >> I can't make out anything on the screen and upon resetting the box, Vista >> boots up with the screwed up refresh rate. >> I'm trying to find a "vga" mode to boot into, but the troubleshooting >> boot menu does not offer it as an option. >> >> The only way I've been able to fix this is to roll back my system using >> system restore, then changing my resolution to 1024 x 768 and then >> allowing windows update to re-install it's previous update. >> >> Using safe mode and setting my resolution to a lower quality does not >> seem to help. On re-boot, the system resumes it's screwy refresh rate. >> >> I've also experimented with the latest Nvidia drivers with the same >> result on resume from standby. >> >> Any suggestions? >> Can anyone tell me how to get the system to use vga mode on boot? >> >> |
| | Re: Resume from standby problem On Wed, 26 Sep 2007 13:03:19 -0500, Leroy wrote: Quote: > Perhaps I should clarify my situation..... > > My monitor defaults to 1680 x 1050 resolution, sweet... I have no problem > with that and I should've stated that first. > When my system goes for a nap it wakes up very cranky with a whacked out > refresh rate. > I cannot see anything and I have to reset the system and go into safe mode. > The only way to fix the problem is to do a system restore to an earlier > time, set my resolution to 1024 x 768, allow any auto updates to occur and > THEN set my resolution back to 1680 x 1050. > And of course then I'm back to square one. > Go for nap, wake up cranky.... > btw, do you have any answers to my questions? drivers. Solution for now is to disable sleep mode on your monitor. I get the same issue in Vista with Nvidia 7900GT but not on XP with same card. |
| | Re: Resume from standby problem Quote: > You have a Nvidia video card, right? It is an issue with their crap Vista > drivers. Solution for now is to disable sleep mode on your monitor. I get > the same issue in Vista with Nvidia 7900GT but not on XP with same card. both these modes cause my issue. I guess I'll just keep using XP until they get better drivers. |
| Vista x64 BSODs on Resume from S3 Standby | General Discussion | |||
| Hang on Resume from Standby | Vista General | |||
| Problem with resume (from S3 standby/sleep) | Vista General | |||
| Desktop resize when resume from standby in RTM | Vista General | |||
| Standby/Resume on nVidia | Vista hardware & devices | |||
