Vista - will two tv tuner cards normally crash?
Old 09-27-2007   #1 (permalink)
markiloon
does anyone have the experience to install two tv tuner cards from
different companies into a computer running Vista? will they normally/
definitely crash with each other?
many thanks for any responses!!
markiloon
Old 09-27-2007   #2 (permalink)
JW
Re: will two tv tuner cards normally crash?
I have seen no reports of tuner cards from different vendors clashing. and
I have seen many reports of users using pairs of analog tuner and pairs of
digital tuner cards from different vendors.
"markiloon" <markiloon@xxxxxx> wrote in message
news:1190903182.239501.15950@xxxxxx
> markiloon
Old 09-27-2007   #3 (permalink)
Charlie Tame
> markiloon
I'd guess that a very old card that has fixed settings might cause a
problem but newer cards should not. Even if it did cause a problem you
might be able to change such things as IRQ etc in the BIOS but if we're
talking Vista there would probably not be any drivers for a card that
age anyway.
I'd suggest you use something like Acronis True Image and make a "Full"
backup when trying anything like this just to be sure you can recover.
Old 09-27-2007   #4 (permalink)
Robert Martin
In theory it should work.
But you'd be better off using two of the same.
If one has Hardware decoding and the other uses Software it may cause a
problem.
I use 2 ATI 550's with no problems in BeyondTV.
Don't try Media Center. It's well worth the money for BTV
I can stream 2 channels at a time over my network.
Or watch the recorded stuff on any pc on the network.
Robert
> markiloon
Old 09-27-2007   #5 (permalink)
markiloon
> markiloon
i am using a Compro Videomate H900 with hardware MPEG2 compression.
yesterday i wanted to add a Winfast PVR3000 Deluxe with hardware MPEG2
compression. i was about to buy it. but four salesmen from four
different computer shops told me two tv tuner cards from different
vendors would VERY PROBABLY clash with each other.
does anyone else other than Robert Martin who also has experiences
that two tv tuner cards do indeed not clash with each other?
again, thanks a lot for any responses!!
markiloon.
Which HDTV tuner cards are best for my 64 bit computer? Graphic cards
will two tv tuner cards normally crash? Vista General
do any TV tuner cards actually work in Vista? Vista music pictures video
# of tuner cards vista will support Vista installation & setup
TV Tuner Cards Vista hardware & devices
