1.    03 Oct 2007 #1
    skytopdesigns Guest
    driver power state failure
    that is the message on the blue screen .
    i am having a problem and i cant figure it out. how do i know what driver.
    i belive that there is a hard drive problem but i havent figured out which
    one. i have 2 hard drives. one seagate and one western digital
    thanks
  2.    05 Oct 2007 #2
    Ace Guest
    Re: driver power state failure
    If I take that error message literally; Windows is telling you that the
    drive's power feed failed while it was in operation.
    Check the cables to your drives for faults, and make sure that your PSU
    can provide enough power to your entire system.
    Power hungry graphics cards may require bigger PSU's.
    =?Utf-8?B?c2t5dG9wZGVzaWducw==?=
    <skytopdesigns@xxxxxx> wrote in
    news:616D9A4F-D062-4865-94AD-EB8CD2AB98C6@xxxxxx:
    > driver.
    > which
    > thanks
    *Reply to newsgroup please.
    *Your mileage may vary.
    *Spelling/Grammar errors free of charge.
  3.    05 Oct 2007 #3
    skytopdesigns Guest
    hmm, havent thought of that. i have been having loads of problems. they are
    posted in the vista general discussion.
    my computer guy seems to think it could be a drive or the mother board ,
    my computer is only 7 months old though and a powerful system. i have 2
    nvidea gforce., ill tell him. he was going to wipe off the c drive and
    reload vista to see if that helps ..
    > > driver.
    > > which
    > > thanks
  4.    05 Oct 2007 #4
    usasma Guest
    RE: driver power state failure
    Here's a link to the error message on your Blue Screen:
    http://aumha.org/a/stop.php#0x9f
    You can locate the dump files on your system (usually in
    C:\Windows\Minidump) in order to analyze them (
    http://forums.majorgeeks.com/showthread.php?t=35246 ) and post the
    information back for a detailed analysis.
    But, to start, I'd update your motherboard/chipset drivers and your video
    drivers - as they are (IMO) the most likely culprits.
    - John
    > thanks
  5.    05 Oct 2007 #5
    skytopdesigns Guest
    you seem to be on the same thought process as my computer guy. but he found
    no updates for the chipset . he too thought they were the problem
    i already updated the video cards and that did stop some other problems.
    > - John
    > > thanks
Driver Power State Failure
Hi All New to forum and relatively useless with computers beyond using simple programs. Recently began experiencing extended shutdown and...
Crashes and Debugging
BSOD- driver power state failure
Thanks for reading my post. I've been using my Gateway laptop for 3 years with relatively few problems. Since June or so, I've been seeing random...
Hi I've been getting this BS error for quite a while now and it is becoming more frequent so I've decided to take action. I have no idea what´s...
Drivers
It seems this is a pretty common occurance lately. 2 Days ago I updated my Vista Home Premium with SP2 and since then it has been crash after...
Driver Power State Failure....
I don't know what this really means but I keep getting the blue screen of death that says Driver Power State Failure. I can't be on for more than an...
Drivers
Driver State Power Failure
Hi i need serious help. I keep getting driver state power failure at shut down. I need some help to this solution. I checked my mini dump file to see...
Vista performance & maintenance
Driver Power State Failure BSOD
Hi all, I've been receiving a Driver Power State Failure BSOD after shutting down/restarting my machine since yesterday. I just installed the Windows...
Drivers
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • PC Help Forum
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
