| | Vista DVD Driver problem I can't run any CDs of any kind in in my LightScribe DVD SuperMulti Drive/CD writer. Which is weird cause I was just listening to an audio CD yesterday. It says in the device manager that the device cannot start(code 10) Details: HP Pavilion a6152n PC Intel Core 2 Quad Processor Q6600 Windows Vista Home Premium 3072MB system Memory 400GB hard drive Device Driver: ATAPI DVD A DH16A1L ATA Device Possible reasons for problem: 1: getting the hpOfficejet 4110 all-in-one printer, fax, scanner, copier, to work on vista. 2: installing the PCSX2 emulator(which did not work) I do know a little bit about drivers, I've had some problems, butI'm not that good. Please presume I don't know anything when you post, it'll make it easier for me to understand. -- Leareth ------------------------------------------------------------------------ Leareth's Profile: http://forums.techarena.in/member.php?userid=32719 View this thread: http://forums.techarena.in/showthread.php?t=831909 http://forums.techarena.in |
| | Re: Vista DVD Driver problem Try this: http://support.microsoft.com/default.aspx/kb/929461 I Bleed Blue and Gold GO BEARS! Quote: >Bless you Cal Bear 66. Your solution worked magic. Thank you, thank you, >thank you. Quote: >"Cal Bear '66" wrote: Quote: > Try this: > > http://support.microsoft.com/default.aspx/kb/929461 > > > I Bleed Blue and Gold > GO BEARS! > > > "Code 10 Error" <Code 10 Error@xxxxxx> wrote in message > news:B5C67ED5-C316-42D6-9B7D-08C480A84969@xxxxxx Quote: > >I am having a similar problem with Vista. My cd-rom stopped working and I > > get a code 10. When I go to update the driver, it says the driver is > > current. I have an exclamation next to the cdrom in the device manager. > > When I uninstall and reinstall, the problem repeats itself. I have a > > Toshiba > > Satellite 215 which comes with a recover disk which tells me everything is > > fine and will not make any changes whatsoever. But its not fine. Every > > tech > > support I call suggests reformatting the hard disk and reinstalling the > > system. This is their answer for every blasted problem with Vista. Either > > that, or they say you have a virus. Frankly, it is extremely frustrating. > > Where can I learn about Vista. In previous versions of Windows there was > > always a backdoor so you could fix drivers and registers etc. Even TweakNow > > is not getting to the root of this problem. The easy way out for these > > remote help desks causes us users a lot of grief. "Leareth" <Leareth.2y9jbf@xxxxxx> wrote in message news:Leareth.2y9jbf@xxxxxx Quote: > > I can't run any CDs of any kind in in my LightScribe DVD SuperMulti > Drive/CD writer. Which is weird cause I was just listening to an audio > CD yesterday. It says in the device manager that the device cannot > start(code 10) > > Details: > HP Pavilion a6152n PC > Intel Core 2 Quad Processor Q6600 > Windows Vista Home Premium > 3072MB system Memory > 400GB hard drive > Device Driver: ATAPI DVD A DH16A1L ATA Device > > Possible reasons for problem: > 1: getting the hpOfficejet 4110 all-in-one printer, fax, scanner, > copier, to work on vista. > 2: installing the PCSX2 emulator(which did not work) > > I do know a little bit about drivers, I've had some problems, but> I'm not that good. Please presume I don't know anything when you post, > it'll make it easier for me to understand. > > > -- > Leareth > ------------------------------------------------------------------------ > Leareth's Profile: http://forums.techarena.in/member.php?userid=32719 > View this thread: http://forums.techarena.in/showthread.php?t=831909 > > http://forums.techarena.in > |
| | Vista DVD drive cannot close sections after writting My DVD/CD RW drive cannot work well with Vista, it can burn a disc, but it cannot close sections or finalize the disc. So, the disc can only be read on my computer, not be read on others. It seems to me that after burnning a DVD, once you click on Eject, Vista cannot close the section! It is a software problem for sure! Thanks in advance for any kind help. |
| | Re: Vista DVD Driver problem *laughs* It turns out that I saw that before, but I thought it was for a different one so I didn't use, guess that'll teach me eh? Thank you for your help, I'm so happy to be able to use my disks again. -- Leareth ------------------------------------------------------------------------ Leareth's Profile: http://forums.techarena.in/member.php?userid=32719 View this thread: http://forums.techarena.in/showthread.php?t=831909 http://forums.techarena.in |
| I have problem starting up Vista - problem with driver | Drivers | |||
| for user that have the driver problem driver. How do we clean inst | Vista installation & setup | |||
| Vista driver problem | Vista hardware & devices | |||
| RE: Vista install problem - Failed to add driver package into driver s | Vista installation & setup | |||
| Vista x32 RC1 ATI driver problem | Vista General | |||
