Vista Tutorial - wireless laser mouse 8000 - BLINKING RED
Old 10-11-2007   #1 (permalink)
mark
Guest
when i try to charge my mouse it does one long slow green blink from under
the roller pad (usual, but)...
then it starts rapid red blinks!
What's wrong
Old 11-11-2007   #2 (permalink)
Tim
Guest
RE: wireless laser mouse 8000 - BLINKING RED
Mark,
The blinking red indicates that battery is not taking the charge from the
base. Try this. Remove the battery and make sure all contacts are clean and
replace battery. If this doesn't fix the problem you will need to replace the
Battery. Use a rechargable NI MH battery only. The sane thing happened to
me. A new battery and it is as good as new.
Tim
> What's wrong
Problem Microsoft Wireless Laser Mouse 8000 - Bluetooth Vista hardware & devices
Re: Microsoft Wireless Laser Mouse 8000 .NET General
Microsoft Wireless Laser Mouse 8000 Vista hardware & devices
Microsoft Wireless Laser 8000 Bluetooth Mouse Vista hardware & devices
