Vista Tutorial - Problem Laser 8000 Bluetooth Mouse
Old 10-17-2007   #1 (permalink)
mark
Guest
Subject: Problem Laser 8000 Bluetooth Mouse
Message: When the mouse is put on the charge pad its green light pulses 8
times slowly. Then a red light flashes continuously and rapidly. The
mouse's NIMH battery does not charge except for a few minutes of use. Even
when the mouse is left on the pad overnight. This problem started early in
August when a Vista update included a prompt to update the mouse driver
software with a download from Microsoft. The Microsoft download was run
and stopped itself with a note that the driver was not compatible. Thatt
is when the mouse stopped charging properly.
Then late August another Vista prompt to download the updated driver for
the mouse, and this time the driver installed. However, the mouse
continues to fail to charge except for less than a minute when it is first
placed on the charge pad.
The mouse battery charge anly lasts a very short while. If I take a half
hour to reseat the mouse on the pad every time the rapid red blinking
occurs, I can slowly build up the charge. The slow green pulsing lasts
about 30 seconds, so in half an hour the mouse is reseated on the charger
pad 60 times.
Microsoft can direct me to a safe driver update, please. That would be
greatly appreciated. It would be really appropriate if Microsoft would
correct the error in its driver update for the Laser 8000 mouse (date of
manufature, 2007).
Mark Stewart, August, September, October 2007
Old 10-17-2007   #2 (permalink)
Computer & Sound System Tech
Guest
Re: Problem Laser 8000 Bluetooth Mouse
forgive me, but if i understand correctly you need the driver to charge the
mouse, couldn't it be that the battery is not holding it's charge, or a
problem with the battery, or is it really the driver not telling the mouse
to charge?
Licensed Boating Capt. Jonathan Perreault
http://www.AllAboutGames.BraveHost.com
- note: click continue, when it ask about security certificate -
Best Comments From Users:
Vista is satan's way to bring hell to earth. -Me
A common mistake that people make when trying to design something completely
foolproof is to underestimate the ingenuity of complete fools. -Web
No Matter The Problem Even With Linux, It's Microsoft's And Windows's
Faults -Everyone
"mark" <mark@xxxxxx> wrote in message
news:0CFED76C-E642-4CD9-BEA1-32803EB3827B@xxxxxx
> pad 60 times.
> manufature, 2007).
Old 10-17-2007   #3 (permalink)
Peter
Guest
I have the latest software - Intellipoint 6.2 and the same mouse and mine
charges OK. You have a dead battery on your hands....replace it.
Peter
Toronto, Canada
> pad 60 times.
> manufature, 2007).
Old 10-17-2007   #4 (permalink)
Guest
this seems(having a dead battery) more plausible than having a driver tell
the mouse it is at the charging station and only charging for a min or two.
that's what i was trying to understand what you were saying.
Faults -Everyone
"Peter" <nobody@xxxxxx> wrote in message
news:%2396zxgMEIHA.1164@xxxxxx
> Peter
> Toronto, Canada
>> Even
>> in
>> first
>> pad 60 times.
>> manufature, 2007).
Old 10-17-2007   #5 (permalink)
samoila_mircea
Guest
The rechargeable battery is dead ... buy a new one... or ask for a
replacement... there is no software problem... Intellipoint only warns you to
recharge it has nothing to do with the recharging itself.
> Faults -Everyone
> > Peter
> > Toronto, Canada
> >> Even
> >> in
> >> first
> >> pad 60 times.
> >> manufature, 2007).
Old 10-17-2007   #6 (permalink)
Guest
i hope mark is reading this, my guess is the battery given to him might be
defectuous if it's brand new or he had it for a long time, and didn't let
his battery die before charging it. this is the worst thing to do to a
rechargable battery charge it before it goes dead, what happens is that the
battery remembers at what point it was charged and take the energy left and
says to it self when i get to this point i need to get charged, so what
happen is next time you use your battery when it gets to that point it'll
send a dead battery signal when you really had 15 min left of use for
example. and over time the battery doesn't work properly anymore and stops
working. now this doesn't happen after the first time you charged your
battery earlier but with time. the trick is once a month let the battery die
completly until the device stops running then charge the battery fully, even
when the signal says battery full, it is only 80% full, let on charger at
least 2 hours for the remaining 20%.
ps this is research information, not something i made up. and applies to all
rechargable batteries
Faults -Everyone
"samoila_mircea" <samoilamircea@xxxxxx> wrote in message
news:F2C1A1CE-4B9D-431F-A30D-E7225C476C83@xxxxxx
> to
>> tell
>> two.
>> completely
>> Faults -Everyone
>> >mine
>> > Peter
>> > Toronto, Canada
>> >> pulses 8
>> >> Even
>> >> early
>> >> in
>> >> driver
>> >> run
>> >> Thatt
>> >> for
>> >> first
>> >> half
>> >> charger
>> >> pad 60 times.
>> >> of
>> >> manufature, 2007).
Old 10-17-2007   #7 (permalink)
mark
Guest
Honestly, whoever you are, drivers don't charge mice. As it happens I have
spent over $20 purchasing batteries, just in case there was a problem with
the battery manufacture. I can absolutely affirm that the faulty manufacture
came from Microsoft: either the mouse driver is faulty, or by some bizarre
fluke the new mouse hardware broke at the very instantr that a Microsoft
driver updated Vista.
Mark
> to charge?
> Faults -Everyone
> > pad 60 times.
> > manufature, 2007).
Old 10-17-2007   #8 (permalink)
mark
Guest
Peter,
You must not have read everything I posted.
Fortunately, I comprehend how to change a battery better than you comprehend
plain text.
Mark
> Peter
> Toronto, Canada
> > pad 60 times.
> > manufature, 2007).
Old 10-17-2007   #9 (permalink)
mark
Guest
How sweet of you to take so much time to explain how a baqttery dies.
Actually, I am lazy and I ALWAYS! let my batteries die before I charge them.
> Faults -Everyone
> > to
> >> tell
> >> two.
> >> completely
> >> Faults -Everyone
> >> >mine
> >> > Peter
> >> > Toronto, Canada
> >> >> pulses 8
> >> >> Even
> >> >> early
> >> >> in
> >> >> driver
> >> >> run
> >> >> Thatt
> >> >> for
> >> >> first
> >> >> half
> >> >> charger
> >> >> pad 60 times.
> >> >> of
> >> >> manufature, 2007).
Old 10-17-2007   #10 (permalink)
mark
Guest
RE: Problem Laser 8000 Bluetooth Mouse
All three of you read this carefully.
The original battery is ancient history and three new NIMH batteries have
dome their best to make the mouse work again.
Something in a Vista update slipped malicious code into the mouse through
it's bluetooth port. This is 'extremely' a well understood exploit - 15
minute blurb on it on the news last week. The mouse is messed up pretty bad.
No more battery talk.
Does any tech have any idea how to do a really effective (and safe)
low-level hardware reset of Microsoft Wireless Laser Mouse 8000?
Sensible answers.
Mark
Peter wrote: [boyscout battery basics]
Computer & So... wrote: [repeat of Peter's good will]
samoila_mirc... wrote: [repeat of peter's good will]
> pad 60 times.
> manufature, 2007).
Problem Microsoft Wireless Laser Mouse 8000 - Bluetooth Vista hardware & devices
Re: Microsoft Wireless Laser Mouse 8000 .NET General
Microsoft Wireless Laser Mouse 8000 Vista hardware & devices
Microsoft Wireless Laser 8000 Bluetooth Mouse Vista hardware & devices
