Xbox wireless controller for PC not showing up in Halo CE menu
  1. #1
    Deadlywill Guest
    Hi all -
    I cannot seem to get the wireless 360 pad for PC to show up in Halo PC. I
    have updated the drivers. Also the controller light is flashing constantly -
    does that mean anything as i've not used one before. I was sure you would be
    able to use this thing for Halo ?
  2. #2
    robbiebaggie Guest
    RE: Xbox wireless controller for PC not showing up in Halo CE menu
    I have same problem, also with other games for Xbox wireless controller.
    "Deadlywill" wrote:
    > Hi all -
Xbox wireless controller for PC not showing up in Halo CE menu problems?
Xbox 360 Wireless Controller will not connect to PC Autobot5150 Vista hardware & devices 18 06 Jun 2009
Halo 2 Images not showing housemaster49 Vista Games 0 02 Dec 2008
Can not install the software of Xbox Wireless Controller for Windo pepefirst Vista hardware & devices 1 07 Aug 2008
Xbox 360 usb controller Madrang Vista hardware & devices 0 07 Dec 2007
xbox 360 wireless controller and vista Paul XxFrEeLaNcExX Butler Vista hardware & devices 2 30 May 2007
