Go Back   Vista Forums > Vista Newsgroups > Vista installation & setup
Vista - 1 CPU detected in dual core system. -Solution
Old 11-07-2007   #1 (permalink)
jaerha
Background:
After reinstall of VISTA Ultimate the experience index has dropped from 5.3
to 4.4 with the CPU giving a lower score than previously. The task manager
only shows one pane for CPU performance in place of the 2 shown previously.
The processor is reported correctly as Intel core 2 CPU 6600 at 2.40 GHz in
Control Panel\System and Maintenance\System. The mother board is a Asus P5K.
Solution in this case:
There seems to be a number of causes that prevent VISTA seeing both cores. I
don't understand the reason that the following works so an explanation from
someone would be helpfull.
Start>Start Search>msconfig
Boot Tab
Advanced Button
The startup number of processors was set to 1 and could not be changed
Unchecked the number of processors checkbox
Check Detect HAL box
Click Apply and Reboot
After reboot the number of detected cores were 2
(Checked with Intel Utility that it detected 2 also task manager now showed
2 and windows experiance index increased from 4.4 to 5.3)
Unchecked detect HAL and selected 2 as number of processors.
Checked make all boot settings permanent under Boot tab.
Reboot
Now BIOS also reports 2 cores instead of previous 1.
Old 11-12-2007   #2 (permalink)
Rabbit
Re: 1 CPU detected in dual core system. -Solution
I just noticed that my dual-cpu dual-core (Xeon 5130 with 4-cores) shows
lower cpu index just recently, and task manager only shows 2 panes (I'm sure
at one time it showed 4).
"jaerha" <jaerha@xxxxxx> wrote in message
news:9CDDDBAD-18E5-4A3E-BB73-BE7EB1A02185@xxxxxx
Quote:
> Background:
> 5.3
> previously.
> in
> P5K.
> I
> from
> Boot Tab
> Advanced Button
> showed
> Reboot
Dual core processor only ones on one core Vista hardware & devices
Vista freezes solid on AMD dual core, single core ok Vista hardware & devices
How come FSX is only using 1 core on a dual core system....... Vista Games
Dual core cpu problem, only one core being found by Vista Ultimate 64 bit Vista installation & setup
Which version support dual core or quad core? Vista General
