Go Back   Vista Forums > Vista Newsgroups > Vista installation & setup
Vista - IIS installation problem
Old 11-12-2007   #1 (permalink)
Retrei
Hi, I got some sickness here.. when I try to install IIS (control
panel/programs and features/features on/off), I DONT SEE any IIS in the list.
Can't install it.. can't find it.. please, please help.
Old 11-12-2007   #2 (permalink)
Rick Rogers
Re: IIS installation problem
What version of Vista are you using? It's not included in the Home Basic
version.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
My thoughts http://rick-mvp.blogspot.com
"Retrei" <Retrei@xxxxxx> wrote in message
news:2992507C-4979-467E-BCE7-C438B1F05807@xxxxxx
> list.
Old 11-12-2007   #3 (permalink)
Dustin Harper
It isn't featured in the Home Basic edition of Vista. That sounds like
that may be the version you are using. If not, let us know and we can
see what else we can do for you.
Dustin Harper
dharper@xxxxxx
http://www.vistarip.com
I am at my end with the installation problem Vista installation & setup
Installation problem General Discussion
Problem in installation! General Discussion
installation problem General Discussion
Installation problem Vista installation & setup
