| | Vista on the C: drive but System drive is the D: drive - any way to I had an issue with one of my disk drives this past weekend and ended up re-installing Vista. My system has two drives; one that I use as the system drive and the other is used for data backup. Well the re- install went fairly well but when I tried to do a complete image backup my data drive today, the one that has the drive letter D: assigned to it, it was not listed as a valid backup device. Further investigation revealed that somehow the D: drive which contains only data and not the operating system is the system partition. The C: drive where all of Vista's files reside is the boot partition. Normally, on non-dual boot systems the boot and system partitions reside on the same physical partition, (and the same physical disk drive). The D: drive was unavailable to use as an image backup drive because it has the system information on it. My question: is there a way to make the C: drive the system partition withput a complete reinstallation? I looked all over the web and at BCDEdit.exe, DiskPart.exe, and BootEdit.exe and none of those appear to be a fix. Anyone have any ideas? Other than that it all works fine. More info below: DISKPART> list volume Volume ### Ltr Label Fs Type Size Status Info ---------- --- ----------- ----- ---------- ------- --------- -------- Volume 0 I Removable 0 B No Media Volume 1 E Removable 0 B No Media Volume 2 G Removable 0 B No Media Volume 3 C NTFS Partition 295 GB Healthy Boot <----------------- Volume 4 K Removable 0 B No Media Volume 5 D NTFS Partition 298 GB Healthy System <-------------- Volume 6 J Removable 0 B No Media Volume 7 F DVD-ROM 0 B No Media Volume 8 H Removable 0 B No Media Volume 9 L Removable 0 B No Media C:\Windows\system32>bcdedit Windows Boot Manager -------------------- identifier {bootmgr} device partition=D: <-------------------------------------------- description Windows Boot Manager locale en-US inherit {globalsettings} default {current} resumeobject {01d9d5d0-9003-11dc-9e1b-f05eb17f0115} displayorder {current} toolsdisplayorder {memdiag} timeout 30 Windows Boot Loader ------------------- identifier {current} device partition=C: <-------------------------------------------- path \Windows\system32\winload.exe description Microsoft Windows Vista locale en-US inherit {bootloadersettings} osdevice partition=C: systemroot \Windows resumeobject {01d9d5d0-9003-11dc-9e1b-f05eb17f0115} nx OptIn |
| | Re: Vista on the C: drive but System drive is the D: drive - any way to move to C: w/o reinstall? There is a misunderstanding here, Your C: drive is the Boot drive, It would not Boot if the system files were on another partition. Your D: drive is not a valid operating system. Delete it . Create a new partition for all your extra program files. Jerry <hinnc@xxxxxx> wrote in message news:098f861a-4b1e-475c-bbc2-fd239ef39d5a@xxxxxx Quote: >I had an issue with one of my disk drives this past weekend and ended > up re-installing Vista. My system has two drives; one that I use as > the system drive and the other is used for data backup. Well the re- > install went fairly well but when I tried to do a complete image > backup my data drive today, the one that has the drive letter D: > assigned to it, it was not listed as a valid backup device. Further > investigation revealed that somehow the D: drive which contains only > data and not the operating system is the system partition. The C: > drive where all of Vista's files reside is the boot partition. > Normally, on non-dual boot systems the boot and system partitions > reside on the same physical partition, (and the same physical disk > drive). The D: drive was unavailable to use as an image backup drive > because it has the system information on it. > > My question: is there a way to make the C: drive the system partition > withput a complete reinstallation? I looked all over the web and at > BCDEdit.exe, DiskPart.exe, and BootEdit.exe and none of those appear > to be a fix. Anyone have any ideas? Other than that it all works > fine. > > More info below: > > DISKPART> list volume > > Volume ### Ltr Label Fs Type Size Status > Info > ---------- --- ----------- ----- ---------- ------- --------- > -------- > Volume 0 I Removable 0 B No Media > Volume 1 E Removable 0 B No Media > Volume 2 G Removable 0 B No Media > Volume 3 C NTFS Partition 295 GB Healthy > Boot <----------------- > Volume 4 K Removable 0 B No Media > Volume 5 D NTFS Partition 298 GB Healthy > System <-------------- > Volume 6 J Removable 0 B No Media > Volume 7 F DVD-ROM 0 B No Media > Volume 8 H Removable 0 B No Media > Volume 9 L Removable 0 B No Media > > > C:\Windows\system32>bcdedit > > Windows Boot Manager > -------------------- > identifier {bootmgr} > device partition=D: > <-------------------------------------------- > description Windows Boot Manager > locale en-US > inherit {globalsettings} > default {current} > resumeobject {01d9d5d0-9003-11dc-9e1b-f05eb17f0115} > displayorder {current} > toolsdisplayorder {memdiag} > timeout 30 > > Windows Boot Loader > ------------------- > identifier {current} > device partition=C: > <-------------------------------------------- > path \Windows\system32\winload.exe > description Microsoft Windows Vista > locale en-US > inherit {bootloadersettings} > osdevice partition=C: > systemroot \Windows > resumeobject {01d9d5d0-9003-11dc-9e1b-f05eb17f0115} > nx OptIn > |
| | Re: Vista on the C: drive but System drive is the D: drive - any way On Nov 14, 11:16 pm, "JerryM" <jerrym...@xxxxxx> wrote: Quote: > There is a misunderstanding here, > Your C: drive is the Boot drive, > It would not Boot if the system files were on another partition. > > Your D: drive is not a valid operating system. > Delete it . > Create a new partition for all your extra program files. > > Jerry<hi...@xxxxxx> wrote in message > > news:098f861a-4b1e-475c-bbc2-fd239ef39d5a@xxxxxx > the system partion. Open your disk administrator and see that your boot and system partitions are one in the same, (unless you dual boot). From Microsoft: "The system partition contains the hardware-related files that tell a computer where to look to start Windows. A boot partition is a partition that contains the Windows operating system files, which are located in the Windows file folder. Usually, these are the same partition, especially if you have only one operating system installed on your computer. When you turn on your computer, it uses information stored on the system partition to start up. There is only one system partition on a Windows-based computer, even if you have different versions of Windows installed on the same computer. A boot partition is a partition that contains Windows operating system files. If you have a multiboot computer that contains, for example, this version of Windows and Windows XP, then each of those volumes are considered boot partitions." So it would appear that the system partition is critical to the startup process. |
| | Re: Vista on the C: drive but System drive is the D: drive - any way to move to C: w/o reinstall? On Wed, 14 Nov 2007 19:17:25 -0800 (PST), hinnc@xxxxxx wrote: Quote: >I had an issue with one of my disk drives this past weekend and ended >up re-installing Vista. My system has two drives; one that I use as >the system drive and the other is used for data backup. Well the re- >install went fairly well but when I tried to do a complete image >backup my data drive today, the one that has the drive letter D: ... Quote: >My question: is there a way to make the C: drive the system partition >withput a complete reinstallation? the partition that has the boot files and from which the computer's BIOS starts to boot, "system partition". The partition that has the Windows system files they call "boot partition". You have to mentally swap those two to make them intelligible. In Windows XP, making a partition bootable used to be very simple. The partition from which you initially boot has to have: 1. A suitable master boot record. (Actually that's on the hard disk, not the partition. Safest way to put it in place is to install Windows on the drive.) 2. The boot files, boot.ini, ntdetect.com, ntldr, and possibly a few others. 3. The partition has to be set active. When these three conditions are met, the computer will happily boot from that drive, even if it is just a diskette. I always keep such a Windows XP boot diskette nearby, just in case the boot stuff gets clobbered on the hard disk. See also http://winhlp.com/node/68 for info on boot diskettes. I don't have complete experience with Vista yet, so please chime in, anyone, to confirm or deny that this is still valid for Vista. Hans-Georg -- No mail, please. |
| | Re: Vista on the C: drive but System drive is the D: drive - any way to move to C: w/o reinstall? On Wed, 14 Nov 2007 19:17:25 -0800 (PST), hinnc@xxxxxx wrote: Quote: >I had an issue with one of my disk drives this past weekend and ended >up re-installing Vista. My system has two drives; one that I use as >the system drive and the other is used for data backup. Well the re- >install went fairly well but when I tried to do a complete image >backup my data drive today, the one that has the drive letter D: >assigned to it, it was not listed as a valid backup device. Further >investigation revealed that somehow the D: drive which contains only >data and not the operating system is the system partition. The C: >drive where all of Vista's files reside is the boot partition. >Normally, on non-dual boot systems the boot and system partitions >reside on the same physical partition, (and the same physical disk >drive). The D: drive was unavailable to use as an image backup drive >because it has the system information on it. > >My question: is there a way to make the C: drive the system partition >withput a complete reinstallation? I looked all over the web and at >BCDEdit.exe, DiskPart.exe, and BootEdit.exe and none of those appear >to be a fix. Anyone have any ideas? Other than that it all works >fine. do this for you. 2. You have to set your motherboard bios to boot from the disk containing the C: drive. Quote: > >More info below: > >DISKPART> list volume > > Volume ### Ltr Label Fs Type Size Status >Info > ---------- --- ----------- ----- ---------- ------- --------- >-------- > Volume 0 I Removable 0 B No Media > Volume 1 E Removable 0 B No Media > Volume 2 G Removable 0 B No Media > Volume 3 C NTFS Partition 295 GB Healthy >Boot <----------------- > Volume 4 K Removable 0 B No Media > Volume 5 D NTFS Partition 298 GB Healthy >System <-------------- > Volume 6 J Removable 0 B No Media > Volume 7 F DVD-ROM 0 B No Media > Volume 8 H Removable 0 B No Media > Volume 9 L Removable 0 B No Media > > >C:\Windows\system32>bcdedit > >Windows Boot Manager >-------------------- >identifier {bootmgr} >device partition=D: ><-------------------------------------------- >description Windows Boot Manager >locale en-US >inherit {globalsettings} >default {current} >resumeobject {01d9d5d0-9003-11dc-9e1b-f05eb17f0115} >displayorder {current} >toolsdisplayorder {memdiag} >timeout 30 > >Windows Boot Loader >------------------- >identifier {current} >device partition=C: ><-------------------------------------------- >path \Windows\system32\winload.exe >description Microsoft Windows Vista >locale en-US >inherit {bootloadersettings} >osdevice partition=C: >systemroot \Windows >resumeobject {01d9d5d0-9003-11dc-9e1b-f05eb17f0115} >nx OptIn |
| Adding a new PageFile on another drive than the system drive | PowerShell | |||
| Can't access external drive on XP - previous Vista Boot Drive | Vista General | |||
| Access XP data drive using Vista Ult (XP drive=slave drive only NO | Vista account administration | |||
| Vista maping drive to server 2000 shared drive not recognize user/ | Vista networking & sharing | |||
| Vista hard drive error check destroys a FAT 16 drive? Help! | Vista hardware & devices | |||
