| | Applications will not start, even though the process does. After having some problems with the installation/update of Adobe reader 8 in Vista Home Premium, I have not been able to run any application, whether from the desktop or from the start meny. Windows base applications will still start and work normally, but when I try to start IE, Mail or any other application, it acts as if it starts, but nothing will show up as a running app. and when I look in the processes, I see it there. |
| | Re: Applications will not start, even though the process does. "DerickB" <derick@xxxxxx> wrote in message news:647A0D95-6175-43A1-9016-B390A2C9AC15@xxxxxx Quote: > After having some problems with the installation/update of Adobe reader 8 > in > Vista Home Premium, I have not been able to run any application, whether > from > the desktop or from the start meny. Windows base applications will still > start and work normally, but when I try to start IE, Mail or any other > application, it acts as if it starts, but nothing will show up as a > running > app. and when I look in the processes, I see it there. this Adobe 8 was not introduced to the system. That would be your temporary fix to get out of it. |
| Setting process priority on applications that require Run as Admin | Vista performance & maintenance | |||
| Start Menu won't launch applications | Vista General | |||
| Start up applications | Vista account administration | |||
| Windows Live Applications Will Not Start | Vista General | |||
| Applications do not start from desktop or from the base Start Menu | Vista General | |||
