| | Suggested fix for expanding files problem I spoke with A microsft rep about my expanding files problem. It seems microsoft has CHANGED the expand subprogram...microsoft needed to let well enough alone. The OLD EXPAND command worked fine...why did they change the way WINDOWS expands files?...MICROSOFT NEEDS to work on this EXPAND NEW command/sub program ---------------- This post is a suggestion for Microsoft, and Microsoft responds to the suggestions with the most votes. To vote for this suggestion, click the "I Agree" button in the message pane. If you do not see the button, follow this link to open the suggestion in the Microsoft Web-based Newsreader and then click "I Agree" in the message pane. http://windowshelp.microsoft.com/com...allation_setup |
| expanding files problem !!! | Vista installation & setup | |||
| Expanding files! | Vista mail | |||
| Problem at Expanding Files | Vista installation & setup | |||
| Another answer to installation expanding files problem. | Vista installation & setup | |||
| error while expanding files | Vista installation & setup | |||
