Go Back   Vista Forums > Vista Newsgroups > Vista installation & setup
Vista Tutorial - INstallation problem
Old 12-10-2007   #1 (permalink)
joe1948
Guest
I am attempting a clean install from 32 bit Home Premium to 64 bit ultimate.
I have inserted the disc and restarted computer, but it just boots into Home
Premium. I bought the OEM full version of Ultimate. Any idea what the
problem might be. Processor is a Pentium 4 3.40.
Joe Holcomb
Old 12-10-2007   #2 (permalink)
Malke
Guest
Re: INstallation problem
You need to set your computer to boot to the optical drive first. Do
this in the BIOS. Then you'll get a prompt to press any key to boot from
the DVD.
Accessing the BIOS
http://michaelstevenstech.com/bios_manufacturer.htm
http://www.uktsupport.co.uk/reference/biosp.htm
http://www.computerhope.com/issues/ch000235.htm
Malke
Elephant Boy Computers
www.elephantboycomputers.com
"Don't Panic!"
MS-MVP Windows - Shell/User
Old 12-11-2007   #3 (permalink)
joe1948
Guest
Thanks for the help. That did solve the problem.
Joe Holcomb
> the DVD.
> Accessing the BIOS
> Malke
> "Don't Panic!"
Old 12-11-2007   #4 (permalink)
Malke
Guest
joe1948 wrote:
Glad to hear it. Thanks for posting back.
Malke
"Don't Panic!"
I am at my end with the installation problem Vista installation & setup
Installation problem General Discussion
Problem in installation! General Discussion
installation problem General Discussion
Installation problem Vista installation & setup
