Go Back   Vista Forums > Vista Newsgroups > Vista installation & setup
Vista - Outlook 2003 problem after using easy transfer
Old 01-05-2008   #1 (permalink)
Rick5547
I am running MS Outlook on Windows Vista Home Premium. Last night I used the
easy transfer to install my profile and mail messages on outlook 2003, along
with other things not related to Outlook. Now I am unable to open the
archive folder. Nor am I able to archive any of my current folders. When
I try to open the archive folder I get an error message that reads "Unable to
expand the folder. The set of folders could not be opened. The server is
not available. Contact your administrator if this condition persists.".
I went to the Outlook Datafiles Mangement and tried to open the archive
folder settings and got the following error: "An unknown error occured code:
0x80040600".
I am running on a stand alone system and I'm the adminisitrator.
Please Help!
Rick5547
Old 01-05-2008   #2 (permalink)
Rick5547
RE: Outlook 2003 problem after using easy transfer
Fixed my own problem. Went back to Outlook and opened up Outlook File
Magement and removed the archive files and then added them back in.
Everything seams to be working fine now.
Rick5547
> 0x80040600".
> Please Help!
> Rick5547
Easiest way to transfer outlook 2003 settings (XP) to Outlook 2007 onnew vista machine? Vista General
Easy Transfer & Outlook Vista file management
transfer emails from Outlook 2003 to Outlook 2007 on new computer Vista General
Easy Transfer - can I import from Outlook Express to Outlook? Vista General
Easy Transfer and Outlook Vista installation & setup
