Go Back   Vista Forums > Vista Newsgroups > Vista installation & setup
Vista - Installation Problems
Old 07-24-2006   #1 (permalink)
=?Utf-8?B?Sm9zZSBJcnVsYQ==?=
I boot the windows Vista from the dvd rom,an error appear on the screen at
the beggining of installation and says (an error occurwith comiunicating
device, well dont explain what device?.
I have a Intel Celron de 2.8 Ghz 533 MHz Supports 64-BIT
DVD ROM, 512 Mb Memory ,HD 40 GB IDE,
Help me.
Its neccesary a AGP or No,
Thanks
Old 07-24-2006   #2 (permalink)
Colin Barnhorst
Re: Installation Problems
AGP is not required.
Disconnect any unneeded devices, especially usb, and try again and then
report back.
"Jose Irula" <JoseIrula@discussions.microsoft.com> wrote in message
news:E824842A-1640-46FF-8372-7A58DE9E118A@microsoft.com...
> Help me.
> Thanks
Installation problems Vista General
Installation Problems Vista print fax & scan
Installation Problems Vista installation & setup
