| | Control Panel does not keep its position Hi All, I have a new Windows Ultimate Installation and changed the Control Panel to Classic View, and also expanded it into the upper part of the monitor, but it does not remember it. How that can be fixed? Thanks, Joe |
| | Re: Control Panel does not keep its position On Mon, 14 Jan 2008 22:32:56 -0500, JoeP wrote: Quote: >I have a new Windows Ultimate Installation and changed the Control Panel to >Classic View, and also expanded it into the upper part of the monitor, but >it does >not remember it. > >How that can be fixed? one possible solution is http://winhlp.com/node/98 . Guaranteed to work. It is particularly interesting if you want the same stability for several other windows as well. Hans-Georg -- No mail, please. |
| | Re: Control Panel does not keep its position Hi There, Is the way it suppose to work in windows Vista? Since in windows XP there is no such problem. Thanks, Joe |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Control Panel does not keep its position You will just need to reset your folder view settings. Method Two in this tutorial will show you how. It will let Vista remember how you last left a window when it was closed again. Windows Explorer Folder View settings Shawn |
| | Re: Control Panel does not keep its position On Tue, 15 Jan 2008 15:24:29 -0500, JoeP wrote: Quote: >Is the way it suppose to work in windows Vista? Since in windows XP there is >no such problem. the problem has always been there a little bit. If you moved the window or opened a second one, it ended up in a different position. Windows Vista has changed the user interface again a little bit, and I'm not yet exactly sure how it works this time. But I don't care. Window Demon solves the problem anyway, for all windows, if you like. Hans-Georg -- No mail, please. |
| | #6 (permalink) |
| | Re: Control Panel does not keep its position Thanks |
| controlling cursor position or other way to control placement of output to screen | PowerShell | |||
| Position menu bar in Computer/Control Panel | General Discussion | |||
| How to position an item in the listview control based on initial l | .NET General | |||
