| | Vista Home Premium problem after installation I have just installed Vista Home Premium on my computer... I had XP before and now when I start up my computer it asks what version of windows I would like to start? How can I tell it to start up Vista everytime? |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Vista Home Premium problem after installation This will show you how to select the OS you want to always startup in. Boot Partition - Default Shawn |
| | Re: Vista Home Premium problem after installation Thank you Brink... Found my own solution... Deleted everything and started over... Im surethe your solution would have been a lot easier... Thank you!! "Brink" wrote: Quote: > > Kmbjerg;610332 Wrote: Quote: > > I have just installed Vista Home Premium on my computer... I had XP > > before > > and now when I start up my computer it asks what version of windows I > > would > > like to start? > > > > How can I tell it to start up Vista everytime? > Hi Kmbjerg, > > This will show you how to select the OS you want to always startup in. > > Boot Partition - Default > > Shawn > > > -- > Brink > > *There are no dumb questions, just the people that do not ask them.* > '*Vista Forums*' > (http://www.vistax64.com/index.php?referrerid=2980) > *Please post feedback to help others.* > |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Vista Home Premium problem after installation Thank you Brink... Found my own solution... Deleted everything and started over... Im surethe your solution would have been a lot easier... Thank you!! "Brink" wrote: Quote: > > Kmbjerg;610332 Wrote: > > Hi Kmbjerg, > > This will show you how to select the OS you want to always startup in. > > Boot Partition - Default > > Shawn > > > -- > Brink > > *There are no dumb questions, just the people that do not ask them.* > '*Vista Forums*' > (http://www.vistax64.com/index.php?referrerid=2980) > *Please post feedback to help others.* > LOL, I'm sure that may help you. If you dual boot again, you will probably still get the boot screen option for the standard 30 seconds to select a OS to boot to before it boots to the default OS. If you do, then just go to the link above and make the adjustments you want for it. Shawn |
| SP2 installation problem in Home Premium 32bit - Arabic language pack? | Windows Updates | |||
| Installation Problem of MS Office 2007 SP1 Update on Windows Vista Home Premium | Microsoft Office | |||
| VISTA: HOME PREMIUM :SOME SOFTWARE INSTALLATION PROBLEM | Vista security | |||
| Application installation problem in VISTA Home Premium. | Vista General | |||
| Striped RAID installation problem with Vista Home Premium 64bit | Vista General | |||
